Gas Tank ??
- Polarity32
Gas Tank ??
12 Jul 2017 05:35 - 12 Jul 2017 05:53
Good morning,
Is it possible to use other years (makes/models) of gas tanks on the 74 kz400 ? Im wondering who has used what , and how it worked..
THANKS
Chad
THANKS
Chad
74 KZ400 , scrambler, cafe project,,, ?? (not sure yet..)
Last edit: 12 Jul 2017 05:53 by Polarity32.
Re: Gas Tank ??
12 Jul 2017 05:52 - 12 Jul 2017 14:24
You can try using the diagrams at Partzilla & Kawasaki.com to figure out what fuel tanks will most likely work. I'd guess the early KZ400s from at least 74-75. maybe a tank from a later model as well. compare the shape & manner of attachment.
If you have a manual fuel valve, you just turn on the fuel valve before starting the engine & then turn it off after stopping the engine.
some guys prefer a manual fuel valve, while others prefer a vac petcock.
Vacuum petcock.
ON & RES. fuel only flows when the engine is running. engine vacuum pulls open a diaphragm to allow fuel to flow by gravity. when the engine is stopped, a spring returns the diaphragm to the closed position. ON is the normal setting for riding.
RES = reserve. use reserve when the fuel level is low. fill up the tank asap after switching to RES. The reserve will usually get you about 15-20 miles of riding before you run out of gasoline & have to push the bike.
PRI = prime. bypasses the diaphragm assy. fuel flows with engine running or engine stopped. use to prime the carburetors. or to drain the tank by installing a long tube in place of the fuel line.
Vacuum petcock.
Last edit: 12 Jul 2017 14:24 by martin_csr.
- Polarity32
Re: Gas Tank ??
12 Jul 2017 06:27
Thanks , for the valuable intel... The vacuum thing is new to me.
Chad
Chad
- Nebr_Rex
Re: Gas Tank ??
12 Jul 2017 19:08As long as the rear of the tank is designed to be held down with a rubber strap.Polarity32 wrote: Good morning,
THANKS
Chad
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Polarity32
Re: Gas Tank ??
13 Jul 2017 07:11Nebr_Rex wrote:As long as the rear of the tank is designed to be held down with a rubber strap.Polarity32 wrote: Good morning,
THANKS
Chad
Ummmm.. Thanks ?
