Cafe racer tailpiece
  • Lnovak7493
  • Lnovak7493's Avatar Topic Author
14 Jun 2017 21:35
#764414
Where would i go about ordering a cafe racer tailpiece? How hard would it be to make one? I want something like whats on drag bikes like the flat square ones that notch up behind where you sit. I would want to modify it to actually have cushion though
1981 kawasaki kz1000-k1 ltd
  • davido
  • davido's Avatar
Re: Cafe racer tailpiece
14 Jun 2017 22:43
#764417
I bought a replica tailpiece off ebay and modified it myself. Starts somewhere here;
www.kzrider.com/forum/11-projects/594313...oject-build?start=80
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • Lnovak7493
14 Jun 2017 23:04
#764418
my father has one that's green from a j model which mine is a j model but the only thing is mine is a ltd. I believe it will workgood though.
  • martin_csr
  • martin_csr's Avatar
15 Jun 2017 05:10 - 15 Jun 2017 05:14
#764424
You say yours is a j model, but a 1000J is not an Ltd. A cafe racer tailpiece really isn't the same thing as a KZ tail cover. not what I'm thinking of, anyway.
Dime city cycles has various cafe racer seats.
Last edit: 15 Jun 2017 05:14 by martin_csr.
  • MDZ1rider
  • MDZ1rider's Avatar
15 Jun 2017 05:36 - 15 Jun 2017 05:37
#764428
Air tech www.airtech-streamlining.com/ makes a wide assortment of body work. It's not typically a direct bolt on. You'll have to fabricate mounts and brackets for your bike.
Last edit: 15 Jun 2017 05:37 by MDZ1rider. Reason: correct link
  • Lnovak7493
15 Jun 2017 08:02
#764440
But its got a factory j model engine just the body makes it a "cruiser"
  • Lnovak7493
15 Jun 2017 08:03
#764441
Anyway thank you guys
  • martin_csr
15 Jun 2017 08:33 - 15 Jun 2017 08:38
#764443
You're confusing things again. remember your chain shock problem? :)
A 1981 KZ1000-K1 Ltd is not a J-model or 1000-J. All KZ1000s from 1981-on had a so-called J-model type of engine.*
Your Ltd frame is different from a 1000J & it's the frame that will determine whether or not a seat or tail cover will fit.
* --- excluding the 1000-C4 police
Last edit: 15 Jun 2017 08:38 by martin_csr.
  • Lnovak7493
15 Jun 2017 19:18
#764475
Yeah but the chain/shock problem was because it had a 70s kz cushdrive. Which has nothing to do with the frame, just the rear wheel assembly. Do you know the difference in the ltd frame and the regular kz frame?
  • Lnovak7493
15 Jun 2017 19:18
#764476
By my vin its a kawasaki kz1000-k1
  • martin_csr
16 Jun 2017 06:11 - 17 Jun 2017 05:41
#764506
The parts diagrams are fairly accurate, so you can compare the frames. Partzilla is easiest. eebbaayy photos can be helpful.
Some guys have done a fairly good conversion from Ltd or CSR to standard or gpz. Some of the changes aren't direct plug-n-play, though.
The Ltd frame is different at the rear & doesn't have attachment points for a tail cover. A standard seat is shaped to fit over a tail cover --- the Ltd seat is different. An Ltd frame usually has a different steering head angle, so there may be more rake in the forks.
The K1 Ltd side covers are different from the J1 & the fuel tanks attach differently. These differences can indicate differences in the frames. The J & K frames are probably the same where the engine & muffler stays attach as they have the same engine brackets & m. stays
Last edit: 17 Jun 2017 05:41 by martin_csr.
  • Lnovak7493
16 Jun 2017 08:45
#764523
I agree with the cushdrive thing your talking about but it was missing and i thought the cushdrives where the same so thats why i said that
