Alternative petcock on stock kz550 g tank
  • alexromega
  • alexromega's Avatar Topic Author
  • first build and lovin it
05 Aug 2016 10:43
#737548
Looking for something that will work better than the crap stock one I have. Anyone?
  • alexromega
Re: Alternative petcock on stock kz550 g tank
05 Aug 2016 10:45 - 05 Aug 2016 10:45
#737549
This is for my stock KZ550
Last edit: 05 Aug 2016 10:45 by alexromega.
  • martin_csr
  • martin_csr's Avatar
05 Aug 2016 11:32 - 05 Aug 2016 18:29
#737554
What's the bolt hole spacing? Some are 44mm, others are 34. If you'd prefer a manual fuel valve, then get one that has the correct spacing. you can find them on eebbaayy. I've seen an oem Yamaha manual fuel valve for pretty cheap. in the $20-30 range. I think it's 34mm. maybe from a yamaha raptor, but I don't recall what years.
Stock vacuum petcock. My 81 650-csr is 34mm. I rebuilt mine with a K&L petcock kit, then several years after that I installed a K&L diaphragm kit. the oem parts may be available.
Last edit: 05 Aug 2016 18:29 by martin_csr.
