Road tac on chrome
  • 9er rider
  • 9er rider's Avatar Topic Author
  • Keep a cool tool
Road tac on chrome
03 Mar 2016 16:56
#713672
Went for a scoot and came home late ,parked my ride and boogied inside and woke up with a delema driping down my pipes aaawww.. does anyone know how to get that inevertant road tac off???
Re: Road tac on chrome
03 Mar 2016 19:28
#713712
Use gasoline, but not when the pipes are hot and don't smoke while using it. Gasoline will dissolve most tarry stuff; just keep the tar wet with it, and give the gasoline some time to soften the tar. Ed
  • martin_csr
  • martin_csr's Avatar
04 Mar 2016 04:39
#713737
I use Liquid wrench silicone spray lubricant to spot clean just about everything on the motorcycle.
On the exhaust pipes you may need to use your fingernail along with the LW stuff. use clean cloths.
  • pete greek1
  • pete greek1's Avatar
04 Mar 2016 08:18
#713779
When I worked paving streets & pothole patching, we had a bucket of Diesel fuel to let the shovels soak for a few minutes & the asphalt would easily come off, & less dangerous than working with gasoline
Pete
04 Mar 2016 08:29 - 04 Mar 2016 08:34
#713780
Could also try soaking the stain a few moments with WD40 before wiping.
Maybe even some Skin-So-Soft? :unsure:
Good Fortune! :)
Last edit: 04 Mar 2016 08:34 by Patton.
  • jdvorchak
  • jdvorchak's Avatar
19 Mar 2016 10:35
#716162
Gasoline, diesel, WD-40, baby oil... Anything.... Even soap and hot water. Anything to help melt the tar. I have used Turtle Wax bug and tar remover on my wife's car. Anything you use just follow up with soap and water wash/rinse. Of course all of this is with the pipes cold.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
  • PLUMMEN
  • PLUMMEN's Avatar
19 Mar 2016 21:08
#716272
Car wash to remove the heavy stuff,then maybe some acetone on the rest. ;)
