'81 GPz gauge disassembly, how bad is it?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: '81 GPz gauge disassembly, how bad is it?
03 Mar 2016 19:35
#713714
Dealing with dim indicators since I bought it in 75. LED's are the way to go. Regular bulbs burn out too quick. That pisses me off too.
03 Mar 2016 19:51
#713716
Nessism wrote:
[IMG
There aren't enough "E"s in "CLEEEEEEEEN" to describe those gauges. VERY nice! Ed
  • JimB
  • JimB's Avatar
05 Mar 2016 20:03
#714041
Hey I don't mean to hijack this thread but this thread got me motivated to work on my 1978 KZ1000 A2 instrument cluster.
Anyway,...I got it all apart and almost altogether and need some information from those who have done this before. When putting the tac and speedo back onto the bracket there was some old black stuff that crumbled and needs to be replaced. I'm sure this is used to dampen vibrations.
In the pic,... I tried to show the area and the black material that I need to replace. It goes between the bracket and the bottom silver of each Tac and Speedo. I cannot tighten the screws until I fill the .5 inch gap with compressible "Gasket" material
So,..does anyone know what this material is? Or,...What can be used to replace this material?
Thanks
Jim
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Mar 2016 20:23
#714045
Some have used a mouse pad for the gasket.
  • Tyrell Corp
  • Tyrell Corp's Avatar
06 Mar 2016 13:08
#714151
Nice work Nessism, I always think clocks are the focal point of a finished bike restoration, also difficult to find in any state for some models.
  • Nessism
  • Nessism's Avatar
06 Mar 2016 17:22 - 06 Mar 2016 17:23
#714192
Thanks for the kind words guys. I try.
The steel parts were bead blasted, epoxy primed, and then top coated with catalyzed urethane. I stumbled onto this Nason fleet paint that's easily the nicest stuff I've ever sprayed. It's amazing. I'm no superlative painter but that stuff sprays out so easily and blends together like glass so even someone like me can get professional looking results.
Sadly, the gauges don't work quite as well as they look. They work fine in steady state but the needles sort or worble during speed changes. Not sure how one would go about fixing that either.
Last edit: 06 Mar 2016 17:23 by Nessism.
