Gps 750 Case Decals
- Irish-Kawi
Gps 750 Case Decals
24 Feb 2016 11:23
Hey KZR Gang,
The GPZ decals on the crank case both sides are a bit marred and scuffed up. I heard that you can get replacements for them (didn't even know they were decals/stickers) so I went over to Z1E and looked there but couldn't find anything, let alone the entire bike decal kit for the graphics. I have a 1985 GPz750 (Zx750-A3) and really want to clean up some of the smaller detail like things on this and know that the case would be a good place to start. Can anyone point me in the right direction?
Thanks,
Brett
Thanks,
Brett
All the gear all the time!
1985 Kawasaki GPz 750 (ZX750-A3) 15,000 original miles www.kzrider.com/forum/11-projects/601230...z750-refresh-project
Father - Husband - Bourbonr - Rider
- peter1958
Re: Gps 750 Case Decals
24 Feb 2016 11:42
www.kzzone.com/
The following user(s) said Thank You: Irish-Kawi
- Irish-Kawi
24 Feb 2016 12:02 - 24 Feb 2016 12:07peter1958 wrote: www.kawasaki-decals.com/kawasakipages6.htm
Thanks Peter will check that out! Are these "identical" factory authorized replacements or just repo's? If repos any idea how good of a repo they are?
EDIT: Checked on the site and didn't see the crank case decals (the metal "sticker" that is round and attaches to the crank case on each side at the bottom), also didn't see the red/white stripe decals either. Sad day but thanks for the assist regardless!
Thanks,
Brett
Last edit: 24 Feb 2016 12:07 by Irish-Kawi. Reason: add info
- MDZ1rider
24 Feb 2016 13:31 - 24 Feb 2016 13:34
Here's another possibility. If you can't find what you're looking for, give them a call. They got some item not listed on the site.
www.diablocycle.com/Z1-KZ-GPz-and-ZX-Models/
Last edit: 24 Feb 2016 13:34 by MDZ1rider. Reason: edit url
- Irish-Kawi
24 Feb 2016 13:33Thanks for the heads up, was not aware that was the case since most list all or at least nearly all of their products. Will reach out and see what I can find, thanks.
Brett
- Irish-Kawi
27 Feb 2016 17:09
Well heard back from a few of the vendors/companies. That specific emblem (the roughly 6" round metallic emblem that has a red ring and says GPz in red lettering on the engine case, both right and left side) is very rare and because it has to withstand high heat and most places don't make them. Those that do apparently are pretty crappy and not something most people would want. They suggested trying to use online communities like ours to try to find a decent original one.
So thats where we are at, trying to locate a GPz engine case original one that is in good condition to replace mine. IF anyone has some or knows who to talk to please let me know.
Thank you,
Brett
Thank you,
Brett
27 Feb 2016 17:28
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
- Irish-Kawi
27 Feb 2016 19:55
- Irish-Kawi
27 Feb 2016 19:58
No eBay APP ID and/or Cert ID defined in Kunena configurationHere is an example of what I am talking about. But one that is in much better condition. In a perfect world I would want a like new "pristine" replacement.
-Brett
-Brett
27 Feb 2016 20:03
I suspect you will need to buy a NOS cover. Good luck.
- Irish-Kawi
27 Feb 2016 20:37I'm beginning to think the same but time will tell I suspect. And to clarify, I'm told that the silver disc/shield that says GPz on it is an adhesive backed emblem and that its replicable which is what lead me on this search to begin with.swest wrote: I suspect you will need to buy a NOS cover. Good luck.
- Brett
- davido
28 Feb 2016 00:53
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
