Seat cover
- strum
Seat cover
09 Feb 2016 07:00
I have never tried to recover a seat but i found a guy on ebay who makes replacements for my bike.
Is this a fairly cut and dry type thing to do or is it best left up to the upholstery shop?
Blairsville Ga.
1980 KZ1000 Shaft (sold and missed already)
2003 ZRX 1200R (sold)
2003 Concours ZG1000 (just purchased)
Re: Seat cover
09 Feb 2016 07:04
Better off getting a seat cover from a known supplier.
- strum
Re: Seat cover
09 Feb 2016 07:14swest wrote: Better off getting a seat cover from a known supplier.
I agree and while fit and quality are issues what im really asking is . how hard is this to do ? given if the replacement is properly made .
it looks like I just stretch it over and secure it on the little barbs unedr the pan. maybe have to use a heat gun to warm it some?
thanks stan
Blairsville Ga.
Re: Seat cover
09 Feb 2016 07:41
If done carefully it can look great. No heat gun required. I put it on the floor and use my knee to get it down enough and don't bend them over until I like how it fits.
Re: Seat cover
09 Feb 2016 07:48 - 09 Feb 2016 09:44
Some guys will say it's easy. others will say it's hard. I guess it's an individual thing. I thought it was hard, but not impossible, and got it done on the first try. I bought a nos seat cover & the material was stretchy which was helpful.
Basically, pry open the prongs to about 45o & remove the old cover. pick off the debris from the foam & sand it if necessary. the foam was split at the center & it had separated from the pan at the front, so I glued those spots using 3M super 77 adhesive spray. let the glue dry overnight.
To attach the cover, I started at the center to make sure the alignment was right & did a test fit first. then sprayed the top of the rear section of foam w super 77 & started fitting the cover over the prongs. after I got the rear fitted, next I sprayed the front section w adhesive & did that part.
The material was stretchy, so it was hard to poke the prongs thru, so I used an awl to make a hole. In short, make mark with prong, poke hole with awl, press prong thru hole, use blunt tool to push material over prong. the instructions said to spray only the top of the seat foam with adhesive (don't spray the sides). All in all I thought it came out pretty good, especially for a first try.
Last edit: 09 Feb 2016 09:44 by martin_csr.
- strum
Re: Seat cover
09 Feb 2016 07:49
No eBay APP ID and/or Cert ID defined in Kunena configurationthanks Steve.. man i have looked and looked and this is the only one i have found for my bike.
Blairsville Ga.
- Mcdroid
- Gone Kwackers
Re: Seat cover
09 Feb 2016 08:34
Don't know about the quality, but the price certainly can't be beat!
strum wrote: thanks Steve.. man i have looked and looked and this is the only one i have found for my bike.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Re: Seat cover
09 Feb 2016 08:49 - 09 Feb 2016 08:49
There is a company out of Thailand called Pit Replica that makes reproduction seat covers via ebay. You might want to check them out to see if they have a match for your bike.
Last edit: 09 Feb 2016 08:49 by Nessism.
- Kapahulu
Re: Seat cover
09 Feb 2016 08:49
I bought my cover from Step Collection on e-bay and it came out great. Not sure if they make a cover for your bike.
www.ebay.com/sch/step-collection/m.html?...armrs=1&_ipg=&_from=
2strokeworld.com
2strokeworld.com
Re: Seat cover
09 Feb 2016 09:25 - 09 Feb 2016 09:29
Mine is a Travelcade/SaddleSkins seat cover. Others have reported that B&H Specialties makes nice seat covers.
motorcycleseatcovers.com
Last edit: 09 Feb 2016 09:29 by martin_csr.
Re: Seat cover
09 Feb 2016 09:29
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
- strum
Re: Seat cover
09 Feb 2016 12:23.martin_csr wrote: Mine is a Travelcade/SaddleSkins seat cover. Others have reported that B&H Specialties makes nice seat covers.
Called this company...got an 87 year old lady who was just a sweet as pie . she is turning it all over to her daughter so they are not doing any right now. maybe in a week or two i can call back she says
Blairsville Ga.
