Csr 650 tank
- Prairie rider 29
Csr 650 tank
13 Sep 2015 15:53
Hello, I am wondering if there is any tanks larger then what's on a 81 csr 650 that will fit and mount fairly easy. Does a 1000 fit on it?
Thanks
Thanks
Re: Csr 650 tank
14 Sep 2015 03:20 - 14 Sep 2015 04:06
The problem with a larger tank is that the upper triple may bang against it & dent the tank.
The 650-CSR triple tree is kinda straight across, whereas other triples are angled forward, allowing clearance.
The 80-82 750E tank is a direct bolt-on (pretty sure) but will get dented. The E tank is 4.2 gal.
A 1000 or Police tank might work but you'll need to get some measurements --- I assume a Big bike has a big tank, so it could be too long. But, as with the 750E, the csr triple will probably ding it.
Last edit: 14 Sep 2015 04:06 by martin_csr.
- Prairie rider 29
Re: Csr 650 tank
15 Sep 2015 05:07
Ok thank you! Do you know of any solo seats that are fairly uncomplicated to add to the 650? Other then cutting the pan and seat that is.
Re: Csr 650 tank
15 Sep 2015 06:09 - 15 Sep 2015 11:21
If you mean like a Harley or Police bike seat, then no, I don't know of anything. One or two of the 750H Ltd models had an unusual 2-piece seat & I think the front part mounts to the frame the same as the csr dual seat. The Ltds have virtually the same frame as the 650-CSR. Partzilla --- seat diagrams --- 80-83 KZ750 H1-H4 models --- unfortunately, they don't show all of the drawings for the 81-on models.
eebbaayy search = KZ750 seat ..... or try DimeCityCycles for something different.
Last edit: 15 Sep 2015 11:21 by martin_csr.
