Z1-R Engine Repaint
- weales
Z1-R Engine Repaint
23 Jul 2015 15:42
Had a very disappointing result from the engine repaint!!!!
I spent a lot of time working the engine externals with wet/dry sandpaper and brass brushes
to get a surface for the new paint to key into. Gave it a good wash down and allowed to dry.
Masked it up and waited for a nice sunny day to take it outside.
I had agonised over which paint to use and thought I was clever to choose POR-15 chassis topcoat
as it's a satin black with very good durability, chemical resistance, and weathering properties.
It's also supposed to fine for Direct to Metal (DTM) so I though "Ok, this is the one!"
Anyway, loaded up the spray gun with suitably thinned paint (POR-15 is quite heavy) and away we went.
Initially looked ok ,then as I progressed the paint finish began to go all krinkly with lumps forming in various places! -too late to stop!
Some areas look fine but others are crap - see pic.
Current Project
1968 Norton P11A Desert Sled
Other bike (and daily ride)
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
- spdygon
Re: Z1-R Engine Repaint
23 Jul 2015 15:48
Wow...that sucks. I heard of a lot of people using that paint without problems.
What kind of soap did u use....I always use Dawn dish soap.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
- weales
23 Jul 2015 15:53
Looks like I'll have to get the wet/dry out again and prepare the surfaces- this time Ill be using rattlepacks,
probably VHT satin engine enamel (my initial choice - wish I'd stuck with it!!!!!
Another pic to show the lumpy/mottley finish, right next to some not so.
(I suspect that a PO has painted the engine with different types of paint, some of which is incompatible with the paint I used. )
Current Project
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
- weales
23 Jul 2015 16:01
Yep, just used a mild dishwashing soap solution - so that should've been ok.
I rubbed back the crappy finish on the clutch cover and applied some of the VHT satin enamel (primer first) over the POR-15.
This came out ok , so will be the way I'll go.
More pics to come after I get the thing prepped - again!! Then painted - again!!
Current Project
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
- z1kzonly
23 Jul 2015 16:22
Man, why did you not do the research here? POR-15 is for rust control, frames and chassis'.
PJ1, VHT, or Plasti-cote rattle cans. Is what you should have used! All Work Great! What did you thin the POR with? Did you use a cheap spray gun from Chinese harbor? You need real chemicals for thinning, real lacquer thinner, urethane grade reducer, base maker.
Sounds like people thinning rustoleum with mineral spirits, and spraying it????
Looks like you got a lot of work to do over?
- weales
23 Jul 2015 16:41
Thought I'd done my homework, but guess not - given the results!!!!
Oh well, I'm not frightened of sharing my failures - hope others can learn from my "experience"
For info -
I thinned the POR with its own POR thinners to get correct consistency for spraying.
Spray Equipment (not el cheapo variety) was cleaned out with POR thinners first before spraying.
Did a test spray on a similar surface and looked to be ok - still think it is a paint incompatibility issue.
In any case it's history now and I "look forward" to another few hours of prep work!
It's winter downunder so plenty to keep me busy in the shed!
For info -
Current Project
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
The following user(s) said Thank You: missionkz
23 Jul 2015 17:29
Maybe too late, but Otkar seemed to have good experience with Guncoat products.
www.kzrider.com/forum/6-paint-a-bodywork...gun-kote-1200#263808
I remember another build by a guy who used a lot of gold Guncoat. It would be interesting to find out how well it has held up for them.
- davido
24 Jul 2015 00:32
I used PJ1 on mine and it came up lovely. Though it hasnt been on the road yet so I can comment on its durability.Fingers crossed itll be good,I dont envy you having to redo it.
You reckon the bad patches are possibly a reaction with the paint underneath.Be sure the new paint isnt going to react badly with the Por !!
Good luck with it.
Good luck with it.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- PaintWorkz
04 Aug 2015 06:16
It is usually a bad idea to paint over someone elses repaint. Always good to do a small test area first to see what happens.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
84 Gpz900 street
77 1135 KZ900 A5
- bountyhunter
04 Aug 2015 14:34Bingo. Always strip to bare metal. Seen that many times. When acrylic enamel first came out in the 70's, that stuff would lift ANYTHING.... including itself! You had to spray it all on quickly. If you tried to come back over it after it had dried it would wrinkle.weales wrote: (I suspect that a PO has painted the engine with different types of paint, some of which is incompatible with the paint I used. ]
04 Aug 2015 16:27
I've used Chassis Coat before and it's not friendly to spraying. It's killer thick and even after thinning it doesn't flow out very well. It looks like the areas where the paint was sprayed straight on are okay, but the overspray started to accumulate on all the adjacent surfaces and build up in a massive layer after layer of orange peel. Sorry for the problems, but I just don't think that's the proper paint for an engine.
- weales
04 Aug 2015 17:14
Thanks to all for feedback - the message is clear, although the paint is not....!
On a more positive note, as a test I painted over an area of the POR with VHT satin finish engine enamel -
after rubbing it back just enough to smooth off the crap wrinkly finish and to provide a key
The end result looks good and I'll post some pics soon.
Current Project
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
