PJ1
- davido
PJ1
16 Apr 2015 06:57
Anybody got any idea what temperature and for how long I need to bake my brake calipers to cure the paint?
I sat the can in a bucket of warm water before spraying,so of course the label came off ! and Ive had no reply from the PJ1 website.
( Its PJ1 Satin black.)
Thanks.
Thanks.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- davido
Re: PJ1
16 Apr 2015 11:08
Aha!
Mr. davido
Thank you for your inquiry. 16-SAT is able to cure on its own once the engine has been started and brought to 250 degrees Fahrenheit then cooled to room temperature.
Hope this helps.
Thank you,
PJH Brands
8747 E. Via de Commercio
Scottsdale, AZ 85258
Direct: 480-385-6740
Fax: 480-607-1550
customer.service@pjhbrands.com
Mr. davido
Hope this helps.
Thank you,
PJH Brands
Fax: 480-607-1550
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Re: PJ1
16 Apr 2015 15:57 - 17 Apr 2015 00:00
After painting my caliper w Duplicolor brake caliper paint, I let the paint cure for a few days (I think it was a few days), then I baked them in the oven at about 150o for about 20 minutes, then raised the temp to 225o for another 20 minutes or so. The paint is tough & has held up well, but brake fluid attacks it --- it's ruined around the bleeder nipple --- not sure if baking at a higher temp would have mattered. doh.
Last edit: 17 Apr 2015 00:00 by martin_csr.
- bluezbike
Re: PJ1
16 Apr 2015 23:20
Not really Martin......I believe that brake fluid is one really effective paint stripper......it's what I am using to clean up some emblems that PO painted all black and it's working well.
79 KZ 1000 LTD
Re: PJ1
16 Apr 2015 23:59
Thanks. I didn't think the baking temp mattered in that regard, but ya never know sometimes. I use brake fluid to strip emblems as well.
