Kz frame paint
- spdygon
Kz frame paint
29 Sep 2014 11:12
Question is what color shade is the black on the frame and rest of parts. Is the black satin?
Black paint I'm using seems a little to glossy.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
Re: Kz frame paint
29 Sep 2014 11:23
Maybe the problem is the frame paint rather than the new paint. The frame paint was pretty glossy when new or when you polish it. Is it possible your frame paint has dulled down over the years? If so, you should be able to polish it up to its original gloss, and that may match the new paint. Ed
- spdygon
Re: Kz frame paint
29 Sep 2014 11:32
Thx...getting ready to paint frame . I have painted some small pieces and the paint looks to shinny...... It is gloss black.
Forum won't take pic from phone will post pic from computer later.
1974 Z1 900 project
1974 Z1 900 project
Re: Kz frame paint
29 Sep 2014 12:28
Here's an image that shows part of my frame. The paint is original. It is pretty glossy; much more so than flat paint would be. Maybe satin paint that was polished after curing would have enough sheen without being super high gloss? Ed
Attachment 00003a_2014-09-29.jpg not found
- Tyrell Corp
Re: Kz frame paint
29 Sep 2014 13:18
Sure, modern base and clear 2 pack can be a bit too good sometimes. That 'dipped in glass' look works great if the prep is right but also highlights defects when it isn't.
One thing doing plenty of wet sanding and high build primer coats on a fuel tank, but chassis parts - a lot of them rough cast with messy welding generally don't get such attention.
Next frame I do I'll use a flatting agent to get a satin look. Usually I can't wait to shoot the clear coats and compounding but sometimes less is more...
Doh! can't post pics (internal server error contact site admin)
- MDZ1rider
Re: Kz frame paint
30 Sep 2014 10:26
I've tried just about every brand of black rattle can I could find over the years, comparing them with original factory painted parts. Here's what I've settled on:
Frame, brackets, seat pan and lower triple clamp - Rustolium Semi-gloss black
Upper triple clamp - Rustolium outdoor Satin black
Engine cases and front hub- PJ1 High Temp Fast Black S (satin)
Paint snobs may laugh, but I tend to stick with Rustolium. The quality is good, It's easy to use, You can buy it anywhere and the price is reasonable. Kawasaki didn't put a lot of time and effort into frame finish. If you're looking for an original appearance, a rattle can of semi-gloss will do fine.
VHT Roll Bar black falls in between satin and Semi-gloss if you feel Semi-gloss has to much shine.
The following user(s) said Thank You: PLUMMEN
- Kapahulu
Re: Kz frame paint
30 Sep 2014 12:04
Yes Rustoleum works well. I'm repainting parts of my H2 right now, mixing 2/3 satin black and 1/3 gloss black. Not a perfect match but close enough for me. I've never had anyone look at my motorcycles and critique the accuracy of the frame paint color.
2strokeworld.com
2strokeworld.com
- spdygon
Re: Kz frame paint
30 Sep 2014 15:48
650ed...ur frame looks purty shinny....
Im been using Rustolem Black Gloss Professional....small parts iv been putting them in the oven to dry.
feel better to know others are using a rattle can as well.
was going to spend the money on powder coat but decided to spend the money on engine.
1974 Z1 900 project
1974 Z1 900 project
- kaw-a-holic
Re: Kz frame paint
30 Sep 2014 17:54Tyrell Corp wrote: Doh! can't post pics (internal server error contact site admin)
reduce your picture size
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- Gman
Re: Kz frame paint
18 Oct 2014 08:10
I have used Rust-Olium 7779 Gloss Black to touch up the factory paint. It is a very close match. My local hardware store carries it.
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
2002 Gold Wing
1974 Z1 900 project
