Adapting a 650 duck tail to a KZP
  • HBKwaka
  • HBKwaka's Avatar Topic Author
25 Sep 2014 07:25
#648743
I found a good deal on a 650 ducktail and now want to adapt it to my KZP. I honestly have no idea how it went on a 650. Are there any diagrams or pics available? TIA
Re: Adapting a 650 duck tail to a KZP
25 Sep 2014 07:48 - 25 Sep 2014 07:49
#648751
There are 4 mounting points for the KZ650 tail; two are vertical (under the seat) and two are horizontal (under the tail). The first image below shows where they are on the bike (circled in yellow). Each of these mounting points uses a bolt, collar, and rubber grommet along with a flat washer and split washer. The second image below shows a tail on eBay that has the collars and rubber grommets installed (circled in yellow). The ones shown are the vertical ones that go under the seat. The horizontal ones under the tail use the same type bolts, washers, collars, and grommets. Ed
Attachment 00003c_2014-09-25.jpg not found
Attachment 00003a_2014-09-25-2.jpg not found
Last edit: 25 Sep 2014 07:49 by 650ed.
  • Grumpy Ole Artist
  • Grumpy Ole Artist's Avatar
  • Eschew Obfuscation!
25 Sep 2014 07:48 - 25 Sep 2014 07:50
#648752
Hafta weld some mounts to the frame in the right spots, but 4 bolts hold it on...2 under the seat, and 2 beside the tail light...hope these help! edit: Ed, ya snaked me by ONE minute, LOL!
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
Last edit: 25 Sep 2014 07:50 by Grumpy Ole Artist. Reason: addtl info
  • pete greek1
  • pete greek1's Avatar
25 Sep 2014 10:27
#648776
That's the same way the 900s & 1000s up to 1980, are attached
Pete
  • HBKwaka
25 Sep 2014 10:30
#648777
MANY MAHALOS Ed and everyone else. Now to find the rear bracket and I should be golden.
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
25 Sep 2014 11:54
#648787
If you have a junk yard nearby, or know someone with an untitled frame, see if you can get the rear hoop and use the brackets off that. I cut this one off a 78' 650 B that had no title, had not run in decades and was only good for parts anyways. This was also adapted to a GPz frame for a ducktail...
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
  • HBKwaka
25 Sep 2014 17:44
#648844
Good idea. Will have a lookabout. Otherwise will fab something. The pics are outfrigginstanding guys!
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
25 Sep 2014 21:02
#648854
C.
  • HBKwaka
26 Sep 2014 17:10
#648917
Have to sign in to view
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
26 Sep 2014 23:58
#648927
Oh damn. Sorry man. I'm a member there, so I just presumed you could see it. Let's try this a different way...
Before:
After:
C.
  • HBKwaka
27 Sep 2014 11:18
#648953
Awesome ISey. Big help for us word challeneged. Pics do it everytime for me.
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
27 Sep 2014 11:48
#648956
10-4 man... glad to help. BTW, yea, they're the small(er) brothers, on the site, but if you want to sign up, there's lotsa info there. Some peps there with mad skills... also!
C.
