KZ1000J Front Fender
- Vintage3
07 Aug 2014 06:36
Hello,
Can anyone tell me if you can remove the front fender on the J model without removing the front wheel? If so I would gather you would use an alan key? Any thoughts or tips on this would be appreciated.
Thanks.
Thanks.
Re: KZ1000J Front Fender
07 Aug 2014 07:17 - 07 Aug 2014 07:18
I'm not familiar with the J model, but isn't the front fender just bolted to the forks with 8mm x 16mm bolts as shown in the Kawasaki.com diagram? If so, you should be able to remove the 4 bolts and slip the fender out like on my KZ650. Did someone modify yours so you need an allen key? Ed
Attachment 00003_2014-08-07-2.jpg not found
Last edit: 07 Aug 2014 07:18 by 650ed.
The following user(s) said Thank You: PLUMMEN
- HBKwaka
07 Aug 2014 07:39
Mine are 10mm and I unbolted it with the tire on. Little fun getting it back on but not too hard.
- Vintage3
07 Aug 2014 07:40
Ed thanks for the microfiche view. I just took a look and this appears to be correct..
Cheers.
Cheers.
07 Aug 2014 07:45HBKwaka wrote: Mine are 10mm and I unbolted it with the tire on. Little fun getting it back on but not too hard.
10mm seems huge for fender mounts. Was that the diameter of the bolt or the wrench size? Ed
- peter1958
07 Aug 2014 07:49
much easyer to take the wheel off then curse trying to get fingers in there
www.kzzone.com/
- HBKwaka
07 Aug 2014 08:26
Wrench size. I jus realized the nomenclature after I posted up. 8 mikes thread size.
