repainting emblems on KZ700
  • Revboyz
  • Revboyz's Avatar Topic Author
14 Jul 2014 13:48
#640063
Any ideas on painting the emblems on my KZ? Its a KZ700 and the side emblems are like gold anodized w a black background..
Why leave well enough alone!
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
Re: repainting emblems on KZ700
14 Jul 2014 16:35
#640087
No eBay APP ID and/or Cert ID defined in Kunena configurationHere's what the colors look like in case someone has a suggestion for the type / color code of paint. Ed
The following user(s) said Thank You: Revboyz
  • kaw-a-holic
  • kaw-a-holic's Avatar
14 Jul 2014 18:29
#640091
Revboyz wrote: Any ideas on painting the emblems on my KZ? Its a KZ700 and the side emblems are like gold anodized w a black background..
So as a comparison, what do the current emblems look like?
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • Revboyz
14 Jul 2014 19:26
#640093
The emblems are weathered the red paint on the "KZ" is chipped and the black paint needs repainting.
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
  • martin_csr
  • martin_csr's Avatar
14 Jul 2014 20:34 - 15 Jul 2014 06:26
#640103
The way I did the emblems & other stuff was to apply a light coating of grease on the raised areas, then spray the black. For the red I used Testor's model kit paint, applied w a brush.
Just touch the grease w your finger tip, then lightly pat to apply - it doesn't take much at all.
After the paint dries to the touch, wipe off the grease.
For the KZ700 emblems I would probably spray the red. After letting the black dry, mask the 700 & apply the grease where needed, they spray the KZ.
Last edit: 15 Jul 2014 06:26 by martin_csr.
The following user(s) said Thank You: PLUMMEN, Revboyz
  • Revboyz
15 Jul 2014 19:01
#640190
Thanks your emblems look good.
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
  • kaw-a-holic
15 Jul 2014 19:20
#640191
I agree with Martin, that's why I was asking about the current condition. As long as the fold is in good condition the red and black should be easy.
Jon
1977 KZ1000a1
Mesa, AZ
  • martin_csr
16 Jul 2014 08:06 - 16 Jul 2014 12:28
#640250
I think some guys don't bother w the grease. They just wipe off the excess paint before it dries.
Applying the grease is a bit tedious, but the emblems are so small it only takes a minute or so.
If necessary if spraying the red, you can probably use a toothpick to apply the grease in the tough spots.
Last edit: 16 Jul 2014 12:28 by martin_csr.
