Changed handle bars!
- CoN2389
21 Jun 2014 11:28
1982 kz550 ltd c
Changed handle bars to european ones. Kind of like sport a lil more rise I think. I need a shorter clutch cable. Does anyone know the length since ik a lot of us have changed handle bars! Also my throttle seems to be getting stuck. It goes when I accelerate but won't snap back. Spring is good. Perhaps it's the new bars and there powder coating? Also front brake is stuck shut. Not sure where that happened during the change out! Thanks for any info guys!
Con
Con
-CoN2389
Re: Changed handle bars!
21 Jun 2014 14:10
You could estimate the needed length of the clutch cable by disconnecting it at the lever, then figure out the overage. Z1Enterprises.com includes the measurements w their cables.
The Motion Pro 03-0030 clutch cable is probably a close match to what you'd need (Z!E # MP03-0030)
For the throttle cables, remove the tank & disconnect them at the carburetors & figure that out. Then see if Z1Enterprises has anything. If needed, Motion Pro makes custom cables.
Stuck front brake: the lever could be binding because of the powder coating? stuck mc piston? clogged mc? stuck caliper piston? stuck caliper from the powder coating??? ... just some possibilities....
- CoN2389
21 Jun 2014 15:18
Thanks for the info bud I got it all sorted out an out back together everything works great just need the carbs synced.
Thanks
Thanks
-CoN2389
