what kind of sanding will leave a matte finish?
- dreblack
21 May 2014 09:44
Hi!
I recently stripped all the paint off of my tank. I did three different coats and scraping, now I just have the faintest traces of paint in a couple spots. Ultimately, id like to keep the tank dull and matte. I don't plan on repainting it. I like the mad max ratty look. BUT, I want to get the rest of this paint off (it looks pink!). What kind of sanding technique will get rid of the paint, but keep the matte finish? I don't mind polishing it up a little bit, but again, would like to keep it ratty.
- PLUMMEN
Re: what kind of sanding will leave a matte finish?
22 May 2014 03:26
Hit it again with the stripper,then clear coat it.
- KowalskiCW
22 May 2014 09:43
I'm doing the exact same thing with the exact same tank and color! I've taken all my paint off with aircraft paint remover and then sanded with a 400 then 600 grit wet sanding in a swirling pattern to just get the metal clean and a consistent pattern on it. I'm going to clear with that 2K Clear in a spray can. I don't have any pics right now but will try to get some up. It's left a fairly matte look to it. Not sure what the clear will do though.
- Killerkz
23 May 2014 08:30 - 23 May 2014 08:31
Why not shoot some matte clear coat? this will give you the matte finish
Last edit: 23 May 2014 08:31 by Killerkz.
- undiablo
23 May 2014 08:35
Not a KZ but and old DNEPR 650 fuel tank clear coated
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- kaw-a-holic
23 May 2014 12:18
+1 I would use a matte finish so you can put several coats of clear on it and get a nice deep finish.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- mykznme
27 May 2014 05:25
I agree with the matte clear but if for some reason you can't find any a green scotch brite will leave you with a nice matte finish and no noticeable scratches.
Cheers,
Cheers,
R.I.P. Odd Ivar
