removing tar and boot rubber off of Chrome??
- dkoz
09 Apr 2014 18:27Attachment IMG_20140409_141357_164.jpg not found
Attachment IMG_20140409_141417_976.jpg not found
anybody have any suggestions on what the best chemical maybe is the use to get my header pipes and mufflers cleaned up
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
1978 Z1R D1
1978 A2
Re: removing tar and boot rubber off of Chrome??
10 Apr 2014 06:04
I use LiquidWrench silicone spray lubricant to clean the wheels & mufflers n stuff. It's also good for cleaning plastic & rubber. If the boot rubber is stubborn, use your fingernail along w the silicone spray.
The following user(s) said Thank You: dkoz
- undiablo
10 Apr 2014 06:11
You should try "Blue Job".
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
10 Apr 2014 06:54
Gasoline and a soft rag. Just be careful with the gasoline. Ed
- dkoz
10 Apr 2014 20:08
Thanks guys ..that blue job looks interesting. The video on the site for the product looks amazing for taking blue and yellowish gold off of your headers. I've ordered some to try.
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
1978 Z1R D1
1978 A2
11 Apr 2014 05:29
Blue Job may work on the boot gunk, but keep in mind that if you overdo it in one spot, you might possibly dull the chrome. I tried the stuff on some exhaust blueing. It removed brown stains from the mufflers but didn't do anything to the header blueing which was pretty bad.
11 Apr 2014 05:42martin_csr wrote: Blue Job may work on the boot gunk, but keep in mind that if you overdo it in one spot, you might possibly dull the chrome. I tried the stuff on some exhaust blueing. It removed brown stains from the mufflers but didn't do anything to the header blueing which was pretty bad.
+1 I would start with the least abrasive approach using chemicals such as gasoline or brake cleaning solvent. Remember - there is no such thing as "chrome polish." Chrome plating can be as thin as 5/millionths of an inch thick. so trying to polish it simply wears it away to nothing very quickly. Solvents that can dissolve the tar can do so without attacking the chrome. Ed
The following user(s) said Thank You: gbot9000
