kz305 tank
- nightrodjc
kz305 tank
03 Apr 2014 06:49
Anyone know if a 81 kz305 tank will fit on a 87 305?? 81 pt no. is 51001...87 pt no. is 51002
Re: kz305 tank
03 Apr 2014 06:56 - 03 Apr 2014 07:01
I'd say yes.
What you can do is compare the diagram drawings at Kawasaki.com or Partzilla to see how similar they are & if they share anything, such as the mounting dampers. I went ahead & did some checks myself, and the frames & tanks look the same.
Last edit: 03 Apr 2014 07:01 by martin_csr.
- nightrodjc
Re: kz305 tank
03 Apr 2014 09:42
Thanks for your help..I found a couple older ones on ebay but need to make sure they will fit my wifes 87 before I order one..
