Gas tank compatability?
- Greasedmonkey
16 Mar 2014 20:09
Ive got a 1980 KZ650 and it needs a new tank. Ive looked around and have found some KZ tanks but none from my year. I would like to know what tanks will fit on it? Can I get one from an older bike or a bigger version? 750 or so and such?
1980 KZ650E
Re: Gas tank compatability?
17 Mar 2014 06:08 - 17 Mar 2014 06:39
I think the Ltd has the same type of "coffin" tank as the 78-79 650D SR models.
The 750-4 tanks attach differently at the rear... most (all?) of them have a bolt.
Yours just fits into a damper.
What you can do is compare the tanks & frames of various models at Kawasaki.com or Partzilla, but I'd guess the best fit would be the ones I mentioned above. If there is a direct bolt-on from another model, it'll probably be from the 70s or maybe an 80 model (750-Twin or 1000)... probably nothing after 1980.
Last edit: 17 Mar 2014 06:39 by martin_csr.
- Greasedmonkey
20 Mar 2014 15:49
Thanks. From what I can tell by feel and what I can see, is that is does just sit in a rubber grommet thing. I cant find a bolt at all.
1980 KZ650E
- jcasterline
20 Mar 2014 18:38
Mine is an 83' kz650 CSR edition. my tank had one bolt on the back, right against the air filter cap. the front of the tank slides over 2 rubber boots/grommets. My tank is fine, but I have often wondered about a larger capacity.
1982 kz 650 CSR mostly stock.
