Any tips on using the 2K Spray Max?
- kzz1king
21 Feb 2014 18:11
Will soon be trying this stuff out I hope. Any tips? Lots of thin coats? Time between coats? Painting is not an area of expertise for me so any info is appreciated! Thanks
Wayne
Wayne
Home built KZ1000 turbo setup
- z1kzonly
Re: Any tips on using the 2K Spray Max?
21 Feb 2014 19:17
Is this the clear coat? or just startin out with the primer?
I assume the clear coat. No thin coats! Wet, medium cover. Shiney lookin at you. Overlap wet coats.
You only need 3 coats at most of clear. Adjust your gun to shot a like "Eyeball" pattern.
No dry coats! Slow even pattern 5-10 minutes between coats. Depending on temp. and the activator, slow, med, high temp range. More confused now?? Ha Ha. Pratice on a piece of anything, Small part or piece of sheet metal. Go with the fastest dry tme stuff. Low temp. Your spray gun will have 2 adjustments fluid and air. Search Youtube, probally a million paint tutorials.
I always shot at the door to fine tune my spray pattern, mostly primer and color.
Good luck, watch some of the car retoration shows. That helps too.
- kzz1king
21 Feb 2014 20:01
Yep, the clear but it is the clear in the spray can with an activator.
Wayne
Wayne
- kaw-a-holic
21 Feb 2014 21:40
This is from their site but for 2K chassis black same mix ratio though.
" APPLICATION INSTRUCTIONS
Ceramic Chassis Black may be applied using an HVLP gun with a 1.3 mm—1.7 mm fluid tip. Apply in two medium wet coats, allowing 15-20 minutes flash between coats. A dry film thickness of 2 mils is recommended. If required for improved flow and leveling, Ceramic Chassis Black may be reduced by up to 10% with a high-quality Urethane-Grade Reducer such as Eastwood’s Zero VOC Reducer (50104ZP)."
Not sure if this helps. There videos on YouTube did not give dry/tack times either.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- Kawboy74
23 Feb 2014 18:04
Make sure you have the correct temperature in the area where you are going to apply it, and for a decent amount of time after. Have all your parts lined up and ready as you only have about 24 - 36 hours to use up the can once mixed together, and that is keeping it somewhat cool. Get any buffing or wet-sanding done as soon as it dries so that you can re-coat soon if necessary. I am waiting for good temperatures to do the same but at $33.00 a can I am not going to waste it.
Good luck.
David
Good luck.
David
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
- kzz1king
23 Feb 2014 19:07
Thanks, I was watching a video on you tube from a company that sells the product. The guy claimed that after 10 hours the product got a little grainy. Good point on the buffing, hoping I wont need to recoat anything. Here is link to video I watched. Other products covered. There 2 part primer sounds good too.
Wayne
Wayne
Kawboy74 wrote: Make sure you have the correct temperature in the area where you are going to apply it, and for a decent amount of time after. Have all your parts lined up and ready as you only have about 24 - 36 hours to use up the can once mixed together, and that is keeping it somewhat cool. Get any buffing or wet-sanding done as soon as it dries so that you can re-coat soon if necessary. I am waiting for good temperatures to do the same but at $33.00 a can I am not going to waste it.
Good luck.
David
- ramtough_63
23 Feb 2014 19:30
I have never used the 2k clear in a spray bomb but the procedure should be the same as any clear
medium wet coats few minutes flash time make sure you take your time and overlap you will see it burn in as you go
couple of coats should do it if your not covering artwork or striping
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- DesertKZ
24 Feb 2014 09:13
I have done a few tanks with this. I always spray a lighter coat first, wait a few minutes, then start laying the wet coats down. 3 or 4 coats should be good, make sure it's between 75 and 85 degrees out.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
1979 CX500C
1975 GT750 Smoker
- richard_oxon
24 Feb 2014 11:19Attachment myz1000paintjob.jpg not found
i used the same spraymax in a can. you need to use it all with in a day or two ,light coat first then keep building it up . a few mins between coats took a while to dry maybe 18 hours or so . i did mine out side on a nice warm day . works nice and gas dosent hurt it at all .
** KZ1000 B3 1979 ** 1015cc wiseco pistons 33 smoothbores ported head 410 cams
** KZ1000 A1 1977** 1075 wiseco pistons 438 megacycle cams ported head rs34 flat slides
- Kidkawie
- I bleed premix
24 Feb 2014 11:20
Read the can or the instructions here:
www.repaintsupply.com/pd_2_part_2k_aerosol.cfm
You'll probably get some orange peel so wet sand it out with 1500 then 2000, then buff with polish and wax.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
The following user(s) said Thank You: kaw-a-holic
