Larger fuel tank on `81 kz1000 LTD
  • LATER
  • LATER's Avatar Topic Author
30 Jan 2014 11:31
#620628
Hi, Has any one mounted a larger fuel tank on a `81 KZ 1000 LTD ,Without cutting the frame? Any and all thoughts are appreciated. LATER.
  • martin_csr
  • martin_csr's Avatar
Re: Larger fuel tank on `81 kz1000 LTD
30 Jan 2014 14:08 - 30 Jan 2014 14:09
#620651
Until someone chimes in w an answer... In general, standard model bikes have larger tanks & the Police bikes' might be bigger as well. A couple of fitment problems are that your upper triple may bang against a larger tank & a different tank may have a different method of attachment at the rear. I believe the triple tree on your bike is kinda straight across, whereas on some models the triple is angled forward which givers more clearance for a larger tank. Search eebbaayy for KZ1000 Ltd forks to see what I'm talking about. The 80 Ltd is angled but not the 81.
Last edit: 30 Jan 2014 14:09 by martin_csr.
