Z1 side covers on 78 LTD
  • nitrokeeb
  • nitrokeeb's Avatar Topic Author
13 Jan 2014 15:13
#618470
Anyone try this swap? I like the older covers better but don't want to lay out the cash if its going to take a lot of fabrication to work.
1978 KZ1000B LTD w/KZ900 engine
  • floivanus
  • floivanus's Avatar
Re: Z1 side covers on 78 LTD
13 Jan 2014 15:37
#618472
The z1 rear motor mounts are where the front sidecover tabs go. You'll also at least need pods or a z1 airbox.
Not sure if the other two tabs are exactly where they need to be though
Past; 78 kz1000, 83 kz550
Andrew
  • turboking
  • turboking's Avatar
13 Jan 2014 15:55 - 13 Jan 2014 15:55
#618476
the upper pin location is the same but the bottom is needed ........ :blink: I welded plates to the frame for the bottom Z1r mount on my 76 kz 900
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Last edit: 13 Jan 2014 15:55 by turboking.
  • wireman
  • wireman's Avatar
13 Jan 2014 16:45
#618487
The top mounts are off just a little bit also.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
14 Jan 2014 01:05
#618524
I have a set of Z1 covers and several early KZ1000's...it appears unanimous...it is do-able with fabrication skills, but you will have to fab up two of the three peg-mounts...seems like a lot of effort.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • nitrokeeb
14 Jan 2014 15:16
#618598
Thanks for all the feedback! I will hold off on this for now. Right now I have one repaired stock cover, and a bolt on repro. I'll just run those for now, and worry about getting buying new covers when I am ready to modify the frame. It's a lot easier to modify than it is to try and put it back to stock!
I bought an aluminum swingarm for my bike when I found a crack in the stock arm next to the pivot. When I found out I"ll have to cut off the passenger peg mount part of the frame (which also provides mounting for the brake pedal and the Kerker). So the old one is now welded up and hope to make it last till I have any future modifications fully planned out.
  • wireman
  • wireman's Avatar
15 Jan 2014 20:07
#618778
You can just trim a little off the inside of the tubes where they hit the swingarm. :)
