z1100 tank swap
- Maravinchi
z1100 tank swap
22 Nov 2013 21:08
Hey new to the forums, looked around couldn't find much info. I was wondering if anyone here has ever swapped a Z 1100 tank onto a kz750 (1983 ltd shaft). Or if anyone knows if it will work with out to much fab work .
Thanks!
Thanks!
Attachment kawa1100-marving.jpg not found
"Quatre roues déplacent le corps, deux roues déplacent l'âme."
1983 KZ750 F1 Ltd-Shaft
- guitargeek
Re: z1100 tank swap
22 Nov 2013 21:29
Howdy & welcome!
Look for a tank from a 1982 GPz750, that's what I used on my KZ750-H1 (LTD750).
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- Mcdroid
- Gone Kwackers
Re: z1100 tank swap
22 Nov 2013 23:25
Guitargeek has a good suggestion. The issue with the GPz1100 fuel tank is that is longer than your current tank...which means that the rear tank mount will not align correctly...which means you will have to move your seat and all it's fittings rearward to accommodate a longer tank. The GPz750 tank is about 5cm shorter than the 1100 tank.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Maravinchi
Re: z1100 tank swap
23 Nov 2013 09:04
Alright thanks alot for the info guys. I'll start looking!
