Side cover o-rings/rubber washers?
  • nickjcoco
  • nickjcoco's Avatar Topic Author
04 Sep 2013 22:54
#604884
Hey all. I ride a 1978 KZ750 Twin. The plastic side covers have a habit of coming off while riding at high speeds. This is annoying, and probably a bit dangerous as I've had to take some concentration off of riding just to make sure they don't go flying behind me into whoever is following. I've noticed the rubber o-rings/washers that hold them on are HORRIBLY worn and was curious if there was a replacement out there? Maybe something at a hardware store I could snatch up or if I have to an OEM or aftermarket option I'm missing. I've done some searching, but am unsure I am wording what I'm looking for correctly.
Thanks!
1978 Kawasaki KZ750 Twin
Cafe project/daily driver
Re: Side cover o-rings/rubber washers?
04 Sep 2013 23:01
#604888
Those grommets (part #92071-056) are still an "Active" Kawasaki part, so any online or local dealer can get them for you. Have the dealer check the number before buying. Partzilla lists them at $1.97 each. Ed
find.partzilla.com/?r=t&q=+92071-056&x=17&y=8
The following user(s) said Thank You: nickjcoco
04 Sep 2013 23:19
#604900
Click here > www.z1enterprises.com/ItemDetails.aspx?i...asaki&item=92071-056
Another option --
Good Fortune! :)
  • nickjcoco
05 Sep 2013 00:46
#604938
Perfect. Thank you so much, both of you.
