Need help stripping/priming tank
  • BIGKEVIN
  • BIGKEVIN's Avatar Topic Author
16 Jul 2013 20:50
#596829
I had my tank off the other day sitting on a work bench while I was working on my carbs. I accidently knocked the tank off and scratched it up. The Kawasaki badges on the side were glued on, so I took them off and put paint removal on both sides were the badves were and on top where the scratches were. I have those parts stripped down to the primer. My question is should I strip the whole tank of just prime the spots I already stripped. I plan on getting the bike painted this winter, so I am not worried about how it looks. Is is possible to prime the areas I stripped today and smooth the prime to the paint that is still on the tank ?
1976 KZ900
2006 ZX6R
  • lightitup
  • lightitup's Avatar
Re: Need help stripping/priming tank
17 Jul 2013 04:31
#596892
if it was mine i would strip it to bare metal and prime it. then paint it the colors you want it to be. if they arent bad scraps and it can wait till winter when u were planing on it anyway then i would also wait.
81 kz 550 ltd
  • BIGKEVIN
17 Jul 2013 21:18
#597000
The scrapes were bad. I ended up stripping most the paint off of the tank today. I will start sanding it tomorrow and hopefully put some primer on it. I couldn't tell if the scratches were to the metal or not and didn't want the same to rust. How many coats of primer do you recommend ?
1976 KZ900
2006 ZX6R
  • gwolever
  • gwolever's Avatar
17 Jul 2013 23:24
#597026
I used 3 coats of primer with a wet sanding between each coat. Worked well for my tank.
Attachment 009_2013-07-17.jpg not found
1982 KZ1000 CSR
  • Cynjut
  • Cynjut's Avatar
19 Jul 2013 01:33
#597246
Dad worked in a paint shop for a while, and he reminded me time and again that primer is relatively porous and that the metal underneath will rust of left unprotected. If you are going to strip and prime, you probably ought to think about (at least) a rattle-can finish. When you are ready to actually paint, strip off the rattle can paint and start over. Since you don't care what it looks like, just get some cheap paint and cover the primer. When it comes time to actually do the paint job right, acetone the "new" paint off, throw on one more coat of primer, and go to town.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
  • BIGKEVIN
24 Jul 2013 22:03
#598139
I got the tank primed today about 6 pm EST. I have 2 good coats on it. How long before I can sand the tank ? I have 220, 400, 600 wet/dry, and 1000 wet/dry. What should I start sanding with ?
1976 KZ900
2006 ZX6R
  • porchev914
  • porchev914's Avatar
27 Jul 2013 01:41
#598517
What did you prime it with? Usually there are recoat instructions on the paint container, giving you flash times, drying times and recommended sanding grits for further finishing. If it's rattle can primer, I'd suggest block it with 400 grit then seal it and top coat it.
FRANKEN Z!
  • goodfastncheap
  • goodfastncheap's Avatar
27 Jul 2013 02:22
#598526
What was the question? It looks like you're all done.
1979 KZ650 B3
KZ Relay Rider #54, Iowa, Nebraska and Kansas
  • BIGKEVIN
08 Aug 2013 20:45
#600483
I decided to spray paint the tank. I got it done today and I have one small run down one side of the tank. What grit sand paper should I use to remove just the run ?
1976 KZ900
2006 ZX6R
  • porchev914
09 Aug 2013 00:22
#600531
1500 wet with a block ;)
FRANKEN Z!
  • BIGKEVIN
09 Aug 2013 19:31
#600628
What grit sand paper should I be using to get the orange peel off ?
1976 KZ900
2006 ZX6R
  • sbc1320
  • sbc1320's Avatar
12 Aug 2013 23:51
#601147
Cynjut wrote: Dad worked in a paint shop for a while, and he reminded me time and again that primer is relatively porous and that the metal underneath will rust of left unprotected. If you are going to strip and prime, you probably ought to think about (at least) a rattle-can finish. When you are ready to actually paint, strip off the rattle can paint and start over. Since you don't care what it looks like, just get some cheap paint and cover the primer. When it comes time to actually do the paint job right, acetone the "new" paint off, throw on one more coat of primer, and go to town.
Good advice right here. I always prime what I strip also. Like you said primer is porous and will rust so topcoating with rattle cans is good to protect it.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
