1981 550 gas tank keys
- Landonn
29 Jun 2013 21:23
I don't have the key to the tank on my 550. Do I have to drill it out or can keys be made? Or are the keys possibly universal?
What would you do if you lost your only key?
Thanks in advance,
Landon
Thanks in advance,
Landon
Re: 1981 550 gas tank keys
29 Jun 2013 23:57
Double check to see if any key that fits the hole will open it. I don't know if that is true on the later bikes or KZ550 models, but I know for a fact that it is true on the KZ650 B & C tank caps and some other KZ models because those locks have no tumblers in them. Ed
- rstnick
30 Jun 2013 00:10
Yeah, try a similar key if you have something that fits, but gently.
If you know the key code #, I can cut you a key.
The # will be on one of the locks, probably the ignition, on the side or back.
Most likely in the Z5000~Z6000 range.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- loudhvx
30 Jun 2013 00:22 - 30 Jun 2013 00:23
As Ed and Rob said, the early 80's 550 tanks are not "keyed". You can even use a long skinny screwdriver to open them. I usually use my house key if the ignition key is not around.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 30 Jun 2013 00:23 by loudhvx.
- Landonn
30 Jun 2013 01:19
Thanks guys. I will investigate. The people on this forum are extremely helpful. Thank you.
- Landonn
30 Jun 2013 02:41 - 30 Jun 2013 02:43
:whistle:
Thank you guys. You guys and WD-40 and graphite...
Attachment IMG_20130629_214322.jpg not found
Last edit: 30 Jun 2013 02:43 by Landonn. Reason: cosmetic
