GOOD DEGREASER FOR ROAD GRIME AND OIL?
  • FlickeredOne
  • FlickeredOne's Avatar Topic Author
08 May 2013 17:31
#586381
I am getting my kz650 engine back from the machine shop on Friday and I want to clean it up before I put it back in the frame. Any good suggestions to cut the junk (keep in mind I have 3 year old gaskets throughout the engine.
BTW - I looked at the forums and searched but didn't come up with anything in a reasonable amount of time.
Thanks in advance!
'77 KZ 650 B1 / '74 Harley SX 125
Re: GOOD DEGREASER FOR ROAD GRIME AND OIL?
08 May 2013 18:16
#586386
  • FlickeredOne
08 May 2013 18:21
#586387
Thanks Ed! I'll Pick some up soon!
  • FlickeredOne
08 May 2013 21:21
#586417
650Ed,
do you have any precautions for this stuff? I've read a bit about it and don't want to trash what I have due to ignorance. Thanks.
08 May 2013 21:51
#586425
On the bottom of my engine I applied it with a parts cleaning brush, let it soak a few minutes, scrubbed it a bit with a toothbrush, and wiped it off. It took a couple applications to get the worst stuff off. If didn't seem to hurt anything. I've used it on other stuff (lawnmower & such) the same way with good results. You might want to wear gloves as it tends to make you hands feel a little slick. I wouldn't use it on paint although I haven't seen it do any damage if a little gets on it and is wiped right off and rinsed. Ed
  • FlickeredOne
08 May 2013 23:19
#586465
It sounds like I had the same game plan in mind. Thanks again.
  • moneypit
  • moneypit's Avatar
08 May 2013 23:47
#586476
Ed you had grime on that engine? From the pics Ive seen it looks like it just came off the factory floor!
2-76 kz900
St Paul MN
  • Jonny
  • Jonny's Avatar
  • woot!
09 May 2013 06:35
#586522
If you end up trying more that one thing, it might be worth you posting up your varied results at the end of your clean up job.
I am in a similar position, tho I still have internal work to finish before the engine gets final cleanup and re-installation. For what it's worth I've had good results with Simple Green, and use it for all kinds of general cleanup. It's cheap, water soluble and biodegradable. Good in my books, and doesn't smell half bad to boot.
Cheers,
Jon
'78 KZ 650C2 'Lila'
'71 Norton Commando 750 'Eadie'
St. Catharines, ON (Mostly, anyway...)
  • Old Man Rock
  • Old Man Rock's Avatar
09 May 2013 07:34 - 09 May 2013 07:34
#586527
Attachment SimpleGreen.JPG not found
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 09 May 2013 07:34 by Old Man Rock.
  • FlickeredOne
09 May 2013 17:27
#586608
... oh wait, I had to catch myself from drooling... Nice work Old Man Rock! 650ED- I've always thought your bike was a bit mythical at how clean you keep it. I appreciate all the input. I will definitely post before and afters on the process.
  • KzChop82
  • KzChop82's Avatar
09 May 2013 23:04
#586653
FlickeredOne wrote: I am getting my kz650 engine back from the machine shop on Friday and I want to clean it up before I put it back in the frame. Any good suggestions to cut the junk (keep in mind I have 3 year old gaskets throughout the engine.
Thanks in advance!
Goo-gone or krud-kutter, stuff is magic with any kind of grease or grime. Gets gum out of carpets too!!
Clinton, NJ
Custom chopper, 1982 KZ 1000 M2 CSR engine, K&N Pod Filters
PICTURES AND GOPRO VIDEOS!! :
www.dropbox.com/sh/jipz3l8nhzr4jge/AABbm...OC3sqlhCSLxH5Fa?dl=0
  • FlickeredOne
11 May 2013 09:23
#586835
There are a lot of crazy nooks and cranny's in these engines. Is pressure washing a bad idea to get the process started? I am planning on covering the exhaust ports and intakes. I have pics but I am having trouble posting them. I used the attachment add file button.
