gas tank wobbles/is loose
- donthaveakawman
31 Mar 2013 03:08
my gas tank is not sitting correctly and wobbles. I think either the mounting brackets with the rubber stoppers are bent or the gas tank is warped, has anyone encountered this problem?
Re: gas tank wobbles/is loose
31 Mar 2013 11:15 - 31 Mar 2013 11:24
Is the rear mounting bolt, damper, & etc installed? And are the 2 center frame dampers in place? The tank should fit fairly solid on the 750H.
Last edit: 31 Mar 2013 11:24 by martin_csr.
- donthaveakawman
04 Apr 2013 16:21
it appears to be more snug on the right side.
sent 5 minutes ago via hand held
- dadgonebroke
02 Aug 2013 15:38
You should have 2 round rubbers on the frame that fit into "receptacles" built into the tank. There are also 2 rubber cushions that sit on the frame (just in front of the seat) that fit between tank and frame. Then there is also a sizable "rubberband" that secures the tank just in front of the seat .
