gauge face replacment question
  • shadow44
  • shadow44's Avatar Topic Author
11 Mar 2013 19:04
#576554
:blink: umm can some one tell me how to get the indicator needle off? got the cover off the tach, ordered new decals from reproduction decals, but I am stumped on getting the needle off so I can remove the gauge face. I looked for a thread covering it already but found nothing :dry:
Remember, the government can not give you anything they have not first, taken from someone else.
  • MFolks
  • MFolks's Avatar
Re: gauge face replacment question
11 Mar 2013 19:20
#576558
Perhaps a watch repair shop might have a hand remover large enough to work, or a clock repair shop.
The following user(s) said Thank You: shadow44
  • shadow44
11 Mar 2013 19:23
#576561
Does it just pull off? I dont wan to break it so i have not applied too much pressure.
  • shadow44
11 Mar 2013 19:36
#576563
Got it! they do just "pull off" I stuck a small screwdriver under the brass piece, where it connects to the steel shaft. Good leverage point to "twist" the screwdriver, and got it loose!
  • mick z1a
  • mick z1a's Avatar
11 Mar 2013 19:41
#576565
the well used method is two spoons, that way you stand less chance of twisting or scratching.
  • pete greek1
  • pete greek1's Avatar
11 Mar 2013 22:26
#576587
Ahhhh , the two spoon trick.....you didnt mention that they have to be bigger than the coke spoons from the 70s, early 80s :silly: :laugh: B)
12 Mar 2013 00:32
#576612
These were very popular. :lol:
Good Fortune! :)
  • CrazyDuck
  • CrazyDuck's Avatar
12 Mar 2013 01:25 - 12 Mar 2013 01:32
#576616
I just did this yesterday! :laugh:
The way that I found to get my needle off was to take either a really thin pair of needle nose pliers or TWO small screwdrivers at the base of the needle where it has the step where it slides on the shaft and it pops right off. Make sure to do it evenly so you don't bend the shaft.
You have to take the screws out for the face plate and move it up so you can get to it. If you just pry on the head of the needle, you are just going to break it.
Okay, so it's a speedometer instead of a tach. That means your job will be far easier than mine was! Just pry at the step where the end of the screwdriver is and beware because it will probably fire across the room. :woohoo:
Attachment IMG_0363.JPG not found
Edit: oooops. I missed the post where he said he got it off. Screw it, I'm leaving the post.
1976 KZ900
1974 TX500
1978 TT500
2007 Aprilia SXV
Last edit: 12 Mar 2013 01:32 by CrazyDuck. Reason: Little late
  • shadow44
12 Mar 2013 10:25
#576654
So how did you get the old decals off?
  • david1050
  • david1050's Avatar
12 Mar 2013 15:13
#576685
Reproduction decals say to sand off the old paint. It's screen printed on not a decal. I think it said start with a 400 grit and finer from there. I stopped at a 800 grit and then messed up the decal appling it(LOL). I then found a speedo on ebay for almost the same price as a new decal.
David
2009 Vulcan 900 Custom
1975 Z1B 900 Mod/Resto project (91 KZ1000P forks and wheels)
1976 KZ900 Cafe bought to flip
1982 KZ750R1/GPZ750 project (95 ZX7 forks, 03 ZX636 swingarm)
  • BlackZ1R
  • BlackZ1R's Avatar
  • Kawasaki in my blood
18 Mar 2013 12:00
#577502
Where are you getting your gauge decals?
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
  • shadow44
18 Mar 2013 12:06
#577503
