Can I get away without using filler? See pics.
  • Hollywoodmx
  • Hollywoodmx's Avatar Topic Author
05 Mar 2013 00:54
#575363
Do you think I can get away without using filler? In the pics if its black I have sanded down past the old paint. Everything is fibreglass save the tank which is something other than metal and fibreglass. I'm just worried if I use filler I will make an uneven surface worse than it is after my sanding. Before sanding it had cracks where the filler was before, probably because it was 20+ years old.
Feel free to provide tips or if I am doing something wrong.
I'm using urethane 2k primer, white base (with a decent HLPV gun), 2k urethane clear.
Attachment 20130223_202033_2013-03-04.jpg not found
Attachment 20130223_202027_2013-03-04.jpg not found
Attachment 20130223_202038_2013-03-04.jpg not found
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • wireman
  • wireman's Avatar
Re: Can I get away without using filler? See pics.
05 Mar 2013 01:12
#575370
As long as its nice and flat Id hit it with some sealer and see how it looks B)
  • lushbaugh
  • lushbaugh's Avatar
  • everybodys a pro......
05 Mar 2013 01:55
#575381
2k primer is high build used as a light filler, lay it on heavy runs dont matter, then block it out. if its slightly deeper within a few millimeters use a good skim coat like usc brand icing. body fillers have come a long long way and theres no need to fear using it as long as its used properly. also i know this seems like a vauge answer but i cant give my opinion unless i actually ran my hand acrost it.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
  • Hollywoodmx
05 Mar 2013 01:55 - 05 Mar 2013 02:00
#575382
wireman wrote: As long as its nice and flat Id hit it with some sealer and see how it looks B)
I don't have any sealer. I have reg shit primer, etching primer, 1k high build primer, and 2k urethane primer. Any of those do?
lushbaugh wrote: 2k primer is high build used as a light filler, lay it on heavy runs dont matter, then block it out. if its slightly deeper within a few millimeters use a good skim coat like usc brand icing. body fillers have come a long long way and theres no need to fear using it as long as its used properly. also i know this seems like a vauge answer but i cant give my opinion unless i actually ran my hand acrost it.
Just the icing without the filler?
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 05 Mar 2013 02:00 by Hollywoodmx.
  • lushbaugh
05 Mar 2013 02:23
#575394
use the urathane primer as modern paints are urathane and 2k is what i always use as it gives you plenty to block on. and icing is a filler its just for thinner imperfections in the ding catagory not dent, its very flexable and awesome to work with, if its deeper than a wave or small gouge youll need a fiberglass specific filler. if its cracked even a little youll need duraglass on the fiberglass or a similar product. i highly reccomend you stay away from bondo brand products and talk to a corvette specialist on the materials you use. they deal with glass on a regular basis and know whats the hot stuff to use.
  • martin_csr
  • martin_csr's Avatar
05 Mar 2013 11:32 - 05 Mar 2013 11:33
#575430
I recall someone here on KZR used 3M Acryl Green to get a smooth even coat over the entire tank. He covered the whole tank w the stuff, using a flexible spreader. It's supposed to be easy to work with.
When searching for the acryl green, I saw another topic in which a 2k filler was used.
Z1000R and Z1000J - Lots of pics, and Gun-Kote oven baked paint.
Last edit: 05 Mar 2013 11:33 by martin_csr.
  • ramtough_63
  • ramtough_63's Avatar
05 Mar 2013 11:43
#575431
Prime everything with primer of choice block sand then spray with a guide coat then resand if no low spots seal and paint
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • Hollywoodmx
05 Mar 2013 12:27
#575436
Wow lots of great info. Thanks guys!
Another question if I'm using urethane primer what kind of paint can it be for the black guide coat?
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • kzz1king
  • kzz1king's Avatar
05 Mar 2013 14:31
#575464
Good info. What is the best type of block for tanks,tail pieces,fenders and such?
Home built KZ1000 turbo setup
  • ramtough_63
05 Mar 2013 15:01
#575465
you eventually sand all the guide coat off its just a light dusting its called Guide coat comes in spray bomb easy to sand I always use a thin
paint stick for a block
I am sure others can give you more modern ways to block everything I have learned was 25 years ago and the last year lol
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • kzz1king
  • kzz1king's Avatar
05 Mar 2013 18:37
#575484
I suck at it. Everytime I think it is ready my buddy keeps finding low spots. I cant see it,think he is just making work for me!
Wayne
  • Hollywoodmx
05 Mar 2013 23:33
#575549
ramtough_63 wrote: you eventually sand all the guide coat off its just a light dusting its called Guide coat comes in spray bomb easy to sand I always use a thin
Cool thanks. I was also doing research on the 2k paints and realized I cant use these in the garage. I have to do it outside and its winter right now so unless I get a good day on the weekend might be a few weeks before I can paint with the 2k stuff anyways.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
