fender cross reference
- natetru
28 Feb 2013 08:01
I have a 1982 kz1000.......my question: can i use a plastic rear fender (cowl) from other years? Found a rear cowl from 1980 shaft drive and dont want to buy it if it wont fit......thanks for your help......
1982 kz1000 m2 csr
- natetru
Re: fender cross reference
28 Feb 2013 11:38
Or an 82 750 spectre rear fender? Trying to get away from the chrome and go painted...
1982 kz1000 m2 csr
28 Feb 2013 12:44 - 01 Mar 2013 11:27
From Kawasaki.com or Partzilla: the E2 Shaft fender is completely different from the CSR's. The Spectre Rr fender looks the same as the CSR in the diagram drawings - ie, same shape & bolt holes. Raise the seat & look at your chrome fender & compare it to the drawings or ebbaayy photos.
Edit: was just clarifying exactly what you needed - the CSR doesn't have the attachment points for a ducktail/cowl.
Last edit: 01 Mar 2013 11:27 by martin_csr.
The following user(s) said Thank You: natetru
- natetru
28 Feb 2013 14:10
Will do....just thought it was a question worth askin...new to the kz so dont know the interchangeable parts yet
1982 kz1000 m2 csr
- DanVVArider
28 Feb 2013 17:19
Ask around on some of the blogs that are big on chopping and bobbing metric bikes. Chances are somebody will have advice for you and a cowl that will match. That was the first think I chucked on my bike.
If you do go with a cowl and removed the chrome fender, look at where the cowl will mount. If the mount bolts or whatever you're using aren't going to show, you could cut and/or drill a cowl to fit the bike.
When you're done or even while this is in progress, post pictures.
"CHOP 'TIL YA DROP!"
