Sport Fairing?
  • badrhino
  • badrhino's Avatar Topic Author
Sport Fairing?
28 Feb 2013 02:13
#574512
No eBay APP ID and/or Cert ID defined in Kunena configurationWhere can you find a sport fairing?
I found this one on feebay but it says 7" headlight. I'm pretty sure mine measures about 8" across.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • badrhino
Re: Sport Fairing?
28 Feb 2013 02:17
#574513
Or do these fairings sit right in front of the headlight instead of them fitting around the headlight?
Franken Z!
  • wireman
  • wireman's Avatar
Re: Sport Fairing?
28 Feb 2013 02:28
#574515
I like those little sport fairings also,never measured one before B)
  • wireman
  • wireman's Avatar
Re: Sport Fairing?
28 Feb 2013 02:41
#574516
My other favorite z1 in the gallery,looks like it sits just in front of headlight
Attachment DSCN1980.JPG not found
B)
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Sport Fairing?
28 Feb 2013 09:22
#574530
badrhino wrote: Or do these fairings sit right in front of the headlight instead of them fitting around the headlight?
If you have an OEM period round Kawasaki headlight, then that is the correct aftermarket fairing.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • pete greek1
  • pete greek1's Avatar
Re: Sport Fairing?
28 Feb 2013 09:59
#574532
No eBay APP ID and/or Cert ID defined in Kunena configurationI bought this one last month for the 900, comes with mounting brackets, hav'nt mounted it yet to see how it looks
  • martin_csr
  • martin_csr's Avatar
Re: Sport Fairing?
28 Feb 2013 11:20
#574538
The size means it fits a standard 7" headlight.
Here's another yellow 1000 that appears to have the same fairing as the one wireman posted.
www.kzrider.com/gallery/kz-1000/finally-1066
  • badrhino
Re: Sport Fairing?
28 Feb 2013 11:42
#574543
My headlight actually measures closer to 8" with the bezel. The last two fairing examples look like there is some room between the headlight and fairing while the first one wireman posted sits in front of the headlight. I do believe it will work however. I just want a little wind protection.
I have also looked for small universal windshields and have found very few. Do you guys know of any of those?
Franken Z!
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Sport Fairing?
28 Feb 2013 11:55 - 28 Feb 2013 12:03
#574546
7 inch refers to the bulb.
if it measures closer to 8 with the ring you prolly have the 7 inch light.
in checking 7 inch bulbs may measure 6 5/8 inch.
anybody know the o.d. of a 7" bulb?
Last edit: 28 Feb 2013 12:03 by 531blackbanshee.
The following user(s) said Thank You: badrhino
  • badrhino
Re: Sport Fairing?
28 Feb 2013 12:02
#574548
Ok, thanks!
Franken Z!
  • 531blackbanshee
  • Vendor
  • Vendor
Re: Sport Fairing?
28 Feb 2013 12:06 - 28 Feb 2013 12:06
#574549
badrhino i edited my post.
i was looking at www.speedwaymotors.com/Speedway-7-Inch-T...Headlights,4407.html
and their advertised 7" bulbs they say measure 6 5/8.
looks like i was wrong.
Last edit: 28 Feb 2013 12:06 by 531blackbanshee.
