Clear coat over original factory paint job.
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
31 Jan 2013 12:08
#570081
I'd like to have the original factory paint top-coated with a durable, super-smooth, clear-coat.
The original is nice, but has fine scratches and ripply orange peel. I assume it will need a tedious thorough wet-sanding, prior to coating. I want the surface like glass!
Any suggestions regarding what finish to use, and if a good auto body shop can achieve the quality level I'm after?
B)
1982 KZ1100-A2/1170 sleeper 😀
Re: Clear coat over original factory paint job.
31 Jan 2013 12:38
#570083
It sounds like a nice idea; just be careful sanding. Many of the KZ's were clear coated from the factory. Some parts (like the tank on mine) have the clear coat applied on top of the pinstripe decals leaving the decals very smooth under the clear coat. On some other parts, like the side covers and ducktail, the decals are raised rather than being smooth. It would probably be pretty easy to damage these decals if the sanding was a little too aggressive. Ed
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
31 Jan 2013 12:49
#570088
There are those who restore/collect older Kawasakis who want the 'orange-peel' as it is a sign of the original factory paint.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Mark Wing
  • Mark Wing's Avatar
31 Jan 2013 12:51
#570089
I would just rough up the paint with a fine scoch-brite and Comet to get it goog and clean then clear it. Put enough clear on to be able to wet sand smooth and polish it up. Like Ed said an aggreseve sanding will danage the paint and well not look good.
Mark
Yorba Linda Cal.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
31 Jan 2013 14:11
#570100
daveo wrote: I'd like to have the original factory paint top-coated with a durable, super-smooth, clear-coat.
B)
If you're having a shop do it they will know what to do. If you want to do it yourself, lightly wet sand the tank with 1000 grit paper and spray it yourself with the Spray Max 2k aerosol clear. You can order it online for $18. Follow the instructions. I would do 3 coats, then wet sand with 1500, then 2000 to remove any peel. Do a final polish with Meguires polish, then wax. Your level of shininess will be determined by your 2000 sanding. Use a pad, you will see how much peel there is.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • ramtough_63
  • ramtough_63's Avatar
31 Jan 2013 16:17
#570105
Mark Wing wrote: I would just rough up the paint with a fine scoch-brite and Comet to get it goog and clean then clear it. Put enough clear on to be able to wet sand smooth and polish it up. Like Ed said an aggreseve sanding will danage the paint and well not look good.
Mark
+1 I use a grey scotch brite (may be better choices) shoot a coat of clear then do my airbrush work
reclear and color sand depending on the art work may have to recoat
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • RonKZ650
  • RonKZ650's Avatar
31 Jan 2013 17:44
#570119
Factory paint is already clearcoated, just for info. At least on all mine it is.
  • daveo
  • Premium Member
  • Premium Member
31 Jan 2013 18:13
#570126
The original clear coat is OK, but I think the factory was more interested in quantity vs. quality.
  • ramtough_63
31 Jan 2013 18:28
#570128
daveo wrote: The original clear coat is OK, but I think the factory was more interested in quantity vs. quality.
Thats why I always scuff clear then art serves 2 purposes gives me known substrate and removal without getting down to original finish if someone wants to change it back
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
