81 kz1000J throttle housing
  • floivanus
  • floivanus's Avatar Topic Author
27 Jan 2013 22:36
#569562
On my 81 j the right hand switch housing/throttle control plastic is broken is this weldable what type of plastic is it?
Past; 78 kz1000, 83 kz550
Andrew
  • dbc92s10
  • dbc92s10's Avatar
Re: 81 kz1000J throttle housing
28 Jan 2013 20:29 - 28 Jan 2013 20:30
#569662
two part epoxy is the best bonds to anything and is superman strong they make it in several different types depending on what you are working with
81 ltd1000
1135 mtc 10.5/1
cavanaugh racing head
38.6/32 p&p
APE k410 cams
APE hardware and tensioner
84 gpz1100 trans
kerker w comp baffle
rs36 carbs
fast by gast race crank
Last edit: 28 Jan 2013 20:30 by dbc92s10.
