Turn Signal Bracket Gasket
  • stocksj
  • stocksj's Avatar Topic Author
25 Jun 2006 07:23
#56932
Hello,
I've been working on restoring my new (old) 82 GPZ750. Yesterday I installed new turn signal assemblies all around. While working on the front turn signal stalks I discovered that I'm missing one of the round rubber gaskets that fit in the bracket attached to the headlight. This round gasket has a diamond shaped opening that the turn signal stalk fits in.
Anyone know where I can find one or if there is a suitable replacement I can find so I can get the other turn signal stalk mounted?
Thanks,
Jim
Woodbridge, VA
  • 77_650B1
  • 77_650B1's Avatar
Re: Turn Signal Bracket Gasket
25 Jun 2006 09:36
#56975
I've made some rubber stuff, like tank dampers. I would think if you had a bit of rubber hose that size, or anything rubber that size really, and shaved it to fit with a razor, it'd work just fine.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
  • letthegoodtimesroll
  • letthegoodtimesroll's Avatar
25 Jun 2006 09:41
#56979
Here is one from a KZ650. It sounds like this might be what you are looking for.
www.partsnmore.com/cat_index.php?model=k...&category=electrical
1977 KZ650C1, Kerker Header, Dyna ignition and coils, GPZ 750 oil pan and cooler
  • stocksj
25 Jun 2006 14:26
#57051
Thanks,
That found the part I needed an I ordered it.
