Minor engine cover damage
  • Spitfire151
  • Spitfire151's Avatar Topic Author
27 Dec 2012 23:47
#564921
So I took off the starter clutch cover on my 1981 KZ440B, it being my first time, I was overly cautious until I got too confident. What I damaged was an opening for a case bolt. Just the crest of the circle snapped off and the bolt can still do in but I've got a little chunk missing. I'm working out of a cold shed so the metal wasn't too forgiving, nor was my ignorance. What kind of epoxy can I use to fix this?
I've heard Loctite Quick Metal would work... thoughts? -Yes 'be more careful next time!'
I just got a jack for the holiday so it will go up on that so I can work on it easier.
  • wireman
  • wireman's Avatar
Re: Minor engine cover damage
27 Dec 2012 23:49
#564924
Picture of damage? B)
  • Spitfire151
28 Dec 2012 00:07
#564931
Sadly it will have to wait until tomorrow, but I can get one.
  • Marklorenzo
  • Marklorenzo's Avatar
28 Dec 2012 18:00
#565007
Worse comes to worse, you could check ebay for one. Maybe post something in Wanted section for a new old cover if you want to have it right.
1984 KZ700 A1
  • Spitfire151
01 Jan 2013 18:26
#565465
Here's a pic:
01 Jan 2013 18:51
#565469
You can pick up a replacement on eBay for about $30. Ed
  • wireman
  • wireman's Avatar
01 Jan 2013 22:21
#565488
Yeah it would be tough to fix that without welding the old piece back on,Id try flee bay also B)
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
01 Jan 2013 23:07
#565491
Yep those aren't too expensive on flea bay. By the way when you get one you should grab a 1000 grit and 1200 grit sandpaper and a polish kit from harbor freight and polish that bad boy.
Marklorenzo wrote: Worse comes to worse, you could check ebay for one. Maybe post something in Wanted section for a new old cover if you want to have it right.
79 LTD B3
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
01 Jan 2013 23:26
#565492
That one is usable until you find one. Roy
  • Topper
  • Topper's Avatar
02 Jan 2013 00:59
#565508
If you want to try and reattach the piece while you shop for a replacement, I'd just go with a little JB Weld.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • Spitfire151
02 Jan 2013 23:50
#565642
Thanks for all of the help, I'll try the epoxy while searching for a new one. I'm just concerned for the aesthetics, it bugs me!
  • Spitfire151
07 Jan 2013 21:33
#566273
Fixed w/ JB Weld:
The second pic's shadow makes the hole look uneven, the bolt goes in just fine and the head will cover the majority of the discoloration Thanks all!
