Handlebars
- cmazzoni16
Handlebars
14 Dec 2012 02:04
I am in the process of changing out my handlebars on my 1981 KZ440 and the bars are too short for the large front master cylinder.
Are there any other alternatives that you can do or any other smaller master cylinders that you can use?
- Primer
Re: Handlebars
14 Dec 2012 04:03
I have seen some nice aftermarket levers with a more modern style remote reservoir that clears up that problem and makes adjusting fluid levels much easier. Of course, you will probably end up replacing the clutch lever to match...
- steell
Re: Handlebars
14 Dec 2012 14:52
Get longer bars. I've seen superbike bars ranging from 27" to 32".
- lushbaugh
- everybodys a pro......
Re: Handlebars
14 Dec 2012 20:48
id use a modern radial master cylinder, solves space and upgrades braking.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- cmazzoni16
Re: Handlebars
16 Dec 2012 19:15
Could you recommend one specific that would work? I am a newbie and I thought that this would be an easy swap. The bars are 28".
Re: Handlebars
16 Dec 2012 23:13 - 23 Jan 2013 13:38
usa-motorcycles-inc on ebbaayy sells new aftermarket Fr Br master cylinders. Find one that's for a single disk - I think those are 12.5mm. A 14mm might be suitable as well. Most have a mirror orifice & note the mount angle. The stock mc mount is usually angled on Ltd models. Flatter bars would need a more level mount.
Last edit: 23 Jan 2013 13:38 by martin_csr.
