Fenderless mod questions?
  • lushbaugh
  • lushbaugh's Avatar
  • everybodys a pro......
Re: Fenderless mod questions?
10 Dec 2012 06:29
#562291
nvm from the side it looked like a side mount and a plenum.... very nice nonethe less
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
10 Dec 2012 12:36
#562319
hth,
The following user(s) said Thank You: K.D. HART
  • K.D. HART
  • K.D. HART's Avatar Topic Author
10 Dec 2012 14:01
#562332
531blackbanshee wrote:
hth,
Thanks leon,
I like that design. I bet it could support the tail light also.
  • K.D. HART
11 Dec 2012 22:22 - 11 Dec 2012 22:24
#562571
I drew up my own design.
I'm going to my local metal shop to have 10GA material sheared 10 1/2 X 20.
I'll also have them break the two sides, so it's like a 3 sided box.
Last time I had something like this made, it was around $10.
I can then take it home, drill my holes, remove (orange shaded areas) with a cutoff wheel and weld the sides, after bending my 45 degree angle.
A, B, and C would be determind by what type of tail light you would be using.
That's why I didn't include those measurements.
If I like the first one, I'll make some more for my other two bikes.
Last edit: 11 Dec 2012 22:24 by K.D. HART.
  • Zedone
  • Zedone's Avatar
12 Dec 2012 19:21
#562689
I have been working on my rear inner fender/tail light also.
First I used bristol board and took all the measurements and them made templates
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
  • Zedone
  • Zedone's Avatar
12 Dec 2012 19:23
#562691
Next I made MDF patterns from them, I used 3/8" MDF. The only reason I used 3/8" is I make lots of templates and it creates less sawdust.
1977 KZ1000A1
  • Zedone
  • Zedone's Avatar
12 Dec 2012 19:42
#562696
Next, I use double sided tape and placed the MDF template directly onto the flat sheet aluminum, I used 6061 T6 aluminum 1/16" thick. In this pic I was making a face plate of my truck stereo, same principle (I can't find the other pic). I used a flush trim router bit (with guide bearing) carbide tipped. This type of router is a fixed base and only 3/4 horse but will work for this very well. One thing that really helps is to pre-cut your flat aluminum piece @ 1/8" or so larger than your final size, this way it is much easier on your bit/ router and you don't have as much mess.
1977 KZ1000A1
  • Zedone
  • Zedone's Avatar
12 Dec 2012 19:52
#562699
I decided also to use 3 pieces. 1 for the inner fender, 1 for the tail light, and 1 for additional support. It turned out not too bad but it still needs work. I first had the rear signal light tabs on the tail light rear plate hanger but they broke off on my brake when I bent them 90 deg so I just cut them off and will use a separate piece the one in the pic will be replaced with a thicker one. This aluminum was @ 1/16" thickness and was a bitch to bend, I think if you anneal it it would be much easier.
1977 KZ1000A1
