bar end weights
  • Topper
  • Topper's Avatar Topic Author
Re: bar end weights
08 Nov 2012 08:57
#557494
Motor Head wrote: If there is that much difference, I would turn down the weight. that way they can be used on another set of bars, if they also are the same ID. If you ream the bars, then then weights will fit those at least. If you change bars then you may well have to ream them also.
So try to shave down the rubber and aluminum of the weights? I imagine I'd need a lathe for that and I don't have one.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • Motor Head
  • Motor Head's Avatar
Re: bar end weights
08 Nov 2012 11:26
#557501
Check your PM's. :)
  • trianglelaguna
  • trianglelaguna's Avatar
Re: bar end weights
08 Nov 2012 11:36
#557502
so it took me ten minutes to plug in a drill and mount them ...the weights are like a 20 spot and bars are just bars
any way you come up with ...this thread has taken hours.... :cheer:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Re: bar end weights
08 Nov 2012 11:59
#557506
Is it for sure that the end-weights aren't a set designed for 1" bars (such as fitted on Harleys) instead of the smaller sized weights designed to fit 7/8" bars?
If the source carries both sizes, possibly the wrong size was furnished.
Good Fortune! :)
  • Topper
Re: bar end weights
08 Nov 2012 12:16
#557507
Patton wrote: Is it for sure that the end-weights aren't a set designed for 1" bars (such as fitted on Harleys) instead of the smaller sized weights designed to fit 7/8" bars?
Good Fortune! :)
The package says they are for 7/8" bars.
Tri, I'm not worried about the time or difficulty here but I don't have a bit that'll do the job. Need to go to the hardware store (an hour and a half drive round trip) and find something that'll work.
1979 KZ750 Twin
  • trianglelaguna
Re: bar end weights
08 Nov 2012 13:08
#557510
bummer
just messin with you
that is the fun of working on stuff...a tiny washer or nut stalls a big build half the time
you'll get em done
1976 KZ900
2003 ZX12R
2007 FZ1000
Re: bar end weights
08 Nov 2012 20:25 - 08 Nov 2012 20:27
#557546
Topper wrote: So there's about a 2mm difference in the inner dimension of my bars and the outer dimension of the weights. I guess I'm going to have to drill out the bars if I want to use these.
Am thinking standard 7/8" steel motorcycle handlebar would have an inside diameter of about 23/32" or 18.256mm (some thinner-walled versions having a slightly larger inside diameter).
7/8" aluminum handlebar would have an inside diameter of about 9/16" or 14.29mm.
What's the inside diameter of the handlebar?
What's the outside diameter of the end-weights?
Good Fortune! :)
Last edit: 08 Nov 2012 20:27 by Patton.
  • Topper
Re: bar end weights
08 Nov 2012 22:14
#557567
I remeasured and the difference is a little less than I thought. About 1mm. The inner diameter of my bars are about 16mm and the outer diameter of the weights are about 17mm.
The hardware store had a sort of grinder to go on my drill that did the trick. It looked like a little mace on a drill bit shaft.
That plus some gentle encouragement with a rubber mallet got them mounted.
Thanks for the help guys.
1979 KZ750 Twin
