bar end weights
- Topper
bar end weights
05 Nov 2012 23:19
I picked up some simple 7/8" bar end weights for my '79 Kz750. I've never used bar end weights before so I'm not 100% sure I'm not missing something but these seem pretty simple.
Problem is these don't fit. They're too big to fit inside my handle bars. Is that typical for these old bikes? Is the inner diameter of the bars smaller than modern bikes?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- Motor Head
Re: bar end weights
05 Nov 2012 23:24
Have you checked that your bars don't have a lip or edge that needs de-burring?
- Topper
Re: bar end weights
05 Nov 2012 23:49
Feels pretty smooth. So regular 7/8" weights should fit?
1979 KZ750 Twin
1979 KZ750 Twin
- Motor Head
Re: bar end weights
05 Nov 2012 23:52
I'd think so, but you got them in your hands there so you will tell.
Do you have the weights backed off all the way, loose for the install?
Pictures always help, also do you have anyway to measure accurately? The weight OD and the bar ID?
- trianglelaguna
Re: bar end weights
06 Nov 2012 00:06
i had a pair of thicker aluminum bars i wanted to try, and the ebay/weights off my chrome superbike bars that had fit fine...would not fit after switching to the aluminum bars,,,,i cant remember but i think i ran a just tight big drill bit in an inch or so and relieved the inside inch of the aluminum bars and then they fit...or something like that...you only need the recessed small end to slide in a bit...the rubber expands and does the real holding
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- trianglelaguna
Re: bar end weights
06 Nov 2012 00:08
you will like em
they balance the ride a bit and are great to keep the bike off the ground in a driveway tip over...give you a bit more to hang helmet on too at stops
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- Motor Head
Re: bar end weights
07 Nov 2012 10:49
Get them to fit your bars?
:huh:
:huh:
- Topper
Re: bar end weights
07 Nov 2012 13:27
Not yet. I wasn't home much yesterday so I haven't been able to work on this.
I need to measure the weights and the inner diameter of the bars to see if I'm going to have to do something like tri suggested. I'm hoping not to have to do that, but I've got a feeling that'll be my only option.
1979 KZ750 Twin
1979 KZ750 Twin
- wireman
Re: bar end weights
07 Nov 2012 14:12
The origional adjustable bar end weights available at kmart or anyplace cheap sporting goods are sold,just tie a fishing line on it and slide it down the end of bars bringing the other end of the line out the bar and under handle bar grip to hold it in place.
Then you you can just slide it to where ever it works best,you can also experimement with differant size weights that will fit inside of bars
Attachment 4966088601p.jpg not found
- Topper
Re: bar end weights
08 Nov 2012 00:13
So there's about a 2mm difference in the inner dimension of my bars and the outer dimension of the weights. I guess I'm going to have to drill out the bars if I want to use these.
1979 KZ750 Twin
1979 KZ750 Twin
- Motor Head
Re: bar end weights
08 Nov 2012 00:28
If there is that much difference, I would turn down the weight. that way they can be used on another set of bars, if they also are the same ID. If you ream the bars, then then weights will fit those at least. If you change bars then you may well have to ream them also.
- trianglelaguna
Re: bar end weights
08 Nov 2012 01:39
good point...i only did it cause it took me a while to switch everything and the grips were drying their glue and so on...turns out i did not like the aluminum bars and they were only on for one ride
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
