Was there ever an actual Paint code??
- ramtough_63
11 Oct 2012 10:08 - 11 Oct 2012 11:00
been doing allot of reading and research about paint codes seems Vintage Kawasaki is amoung a few that never released a paint code (according to something I read)
I have also noticed that most paint companies that advertise color correct is "their version"
now I know most of these were candy colors which is tough to reproduce but there are color codes for
factory candy paints and not just suppliers versions
just wondering if their are any old timers who were painting these back then and who the paint mfgr
might have been.
might have been.
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Last edit: 11 Oct 2012 11:00 by ramtough_63.
- ramtough_63
Re: Was there ever an actual Paint code??
11 Oct 2012 10:56
h=found this from a company who does their verson of Honda paints
seems plausable and must be true because its on the internet
A common misconception exists concerning automotive/motorcycle paint. It is widely held that the color codes found on the ID tags of countless car bodies since the 1930s can be taken to any auto paint jobber and that he can from that number mix a perfectly matching batch of paint. Unfortunately, it isn't usually that simple. In the first place, the paint which manufacturers spray on their motorcycles and vehicles is not available for retail sale. During manufacture, paint technicians from large paint distributors would come to the factory and take samples of finished painted parts to analyze at their facilities. They then formulate replacement paint based on those samples. The jobber hand mixed paint that doesn't always match what the factory sprayed on the vehicle and motorcycles, for a number of reasons. As already emphasized, it isn't the same paint, for one thing. For another, manufacturers have more than one assembly plant in most cases, and samples are usually taken from just one run at one plant. Furthermore, all painted finishes begin degrading, color-wise (and candies such as Honda's 70s finishes the fastest), and this means that the samples taken by the paint jobbers vary considerably from the paint on our vehicles within just a few months. Add to this variables in application technique, humidity and material reduction (how and how much the paint is thinned), and the result is that color matching for repair and restorative purposes is more art than science.
The paint situation with Honda motorcycles is even more complicated. To begin with, as is the case with most motorcycles, after-the-sale paint availability has been spotty at best, with such availability having taken three different forms during the company's history. The first time, during the 60s, a small (about 3 oz.) can of Japanese-labeled touch-up paint (not the original paint use by Honda manufactures); The second time was during the 70s, when American Honda formally endorsed the product of an American aftermarket lubricants company called Lubritech, whose fork oil was specified by Ceriani in its early forks. Lubritech, much the way manufactures do today with cars, attempted to matched the factory paints for most manufacturers during that early (70s) period. The third time was in 1982, the product of the Los Angeles-based paint jobber (who simultaneously sold the same paint direct to the consumer) who matched to Honda's then new automotive-type color code system used today. Within a very short time, the company was sold.
To summarize, there are NO PAINT CODES with which to mix paint for Hondas made before 1982. All available Honda paint is an after-market product that was either closely matched or in known cases, simply sold from stock color by DuPont, PPG or HOK (not even close to Honda OME by today's standards). Even Lubritech's numbers are merely their part numbers, not part of a color code system. Honda didn't use anything we recognize in the U.S. as a standard automotive color code scheme until 1982. From 1982 onward, Honda does use a conventional automotive-like paint code system, however just as in the automotive world, the paints are available only on the aftermarket and some fudging is inevitably required to get a perfect match.
Vintage CT70 Restorations has quickly gained recognition as a leader in the early Honda motorcycle paint industry. Their Honda OME paint matching techniques have produce amazing results by trial and error reproducing the 60's-70's Honda OME colors. Today's urethane system is not the same process and paint used in the early days of Honda. Today’s candies are a 3-stage process that produces a much deeper metallic longer lasting finish. Vintage CT70 Restorations uses only the best available candies products and ChromaBased paints. They custom mix ALL their paint to obtain the proper shade while using the correct metallic flake size and colors in the basecoats.
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
11 Oct 2012 11:34
Matching the paint exactly would be pretty difficult because the underlying coats also need to match. Way back when Lubri-Tech sold paints that could be used to get a good match (maybe not perfect), but they are long gone. In the Lubri-Tech charts below you can see that the Metallic Regal Blue (my bike's paint) was a 4 step process using 2 different silver undercoats then blue then clear. Unfortunately, I doubt there is a single paint that can match the effect of that process. Ed
Attachment PaintChart1.jpg not found
Attachment PaintChart2.jpg not found
The following user(s) said Thank You: ramtough_63
Last edit: 23 Jan 2013 11:38 by martin_csr.
- ramtough_63
11 Oct 2012 12:46
That is super cool info Ed I'm going to take those charts to Kinkos blow them up
its kind of a shame more of they guys who have cracked the code so to speak dont share that info
but I understand it.
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
