rattle job
- kzinaz
rattle job
16 Jun 2006 19:58
i have a question about a rattle can paint job. i'm going with a flat black and was wondering if a clear coat would take too much away from the "flat" black. oh here is a pic finally.
- Werewolfx
Re: rattle job
16 Jun 2006 20:30
I think you can get flat or atleast satin clear coats, but I don't know about pre-mixed in rattlecans..You may be able to get a paint shop to properly mix some for you and put it in one of those little sprayers with the glass jar on the bottom.
Chris
- Mark Wing
Re: rattle job
16 Jun 2006 20:32
Clear would make it shiny. The best you can get in rattle cans is semi gloss clear. Even cleared with rattle cans you should use a rag to catch any drips when gassing up.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- Pterosaur
Re: rattle job
16 Jun 2006 20:34
If you clear a flat black tank with clear gloss, you'll have a gloss black tank.
As previously mentioned, there's satin-finish clears, and if anybody 'll have it in a rattlecan, it'll be PJ-1...
Hope that helps...
Hope that helps...
- 1983LTD750
Re: rattle job
17 Jun 2006 08:21
check my post in the new members forum and see my rattle can job.
its a metallic paint for wheels, so it will stick to bare metal. And the black stripe is just regular Rustoleum black. The center stripe is just black paint and while it was wet, I just put some saran-wrap on top of it and squished it around.
Its got 3 coats of rattle can clearcoat on it too.
but yeah, I still carry a rag underneath the seat to catch any drips from re-fueling.
- Fossil
Re: rattle job
17 Jun 2006 08:56
I assume you want to clear coat it for durability? I've found the Duplicolor engine enamels with ceramic to go on quite smooth and stand up better than any other spray can paint I've found. I used the low gloss black (satin) on my engine and the gloss black on a few brackets, brake pedal and my rear wheel.
