Don't have 'em. Need 'em. Where to find 'em?
- Killman
- Now with 99% more ducks
03 Sep 2012 13:55
Remembered I'm going to need the doodads that secure the side cover badges onto the side covers. Looked on Kawasaki.com, but they aren't labelled or listed.
Little help?
Little help?
1983 kz440 ltd
Quack
Quack
- Motor Head
Re: Don't have 'em. Need 'em. Where to find 'em?
03 Sep 2012 14:01
Most any of the Auto Stores that have clips and fasteners for body work will have them, cheap I'm sure. Ace Hardware may even have them, as they have several different fasteners. They are just a washer with multiple fingers in the middle, so it grabs the stud when you push it on. Or you can get some Plastic nuts that will self thread onto the small studs/ posts of the emblems.
- kaw-a-holic
03 Sep 2012 14:18Do you have an ACE Hardware? They have them there. They are called crush nuts. They do have grommets that will work also.Killman wrote: Remembered I'm going to need the doodads that secure the side cover badges onto the side covers. Looked on Kawasaki.com, but they aren't labelled or listed.
Little help?
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
03 Sep 2012 14:21
Perhaps I miss led you there my 77 KZ1000a1 uses crush nuts with pan head bolts.
Jon
1977 KZ1000a1
Mesa, AZ
1977 KZ1000a1
Mesa, AZ
- GregZ
03 Sep 2012 23:26
3mm nut(clip) part # 92018-003 Kwack dealer sells thems this part number is for z1 kz side cover emblems. Correct for your bike I don;t know. there exp. $2 something apiece
- wireman
03 Sep 2012 23:28
If the pins arent long enough to get the nuts on them try a little dab of silicone on back side of emblems before pushing them in
04 Sep 2012 10:10
Skyman posted that he cut threads on the studs, then installed some nylon lock nuts or something. So that's what I did & added a dollop of silicone caulk to make sure the nuts stay in place. Doing so makes emblem removal much easier for the next time.
- Killman
04 Sep 2012 10:25
As usual you guys are awesome.
I have a question though, aren't the studs plastic? What would I use to cut threads on them without mangling the little suckers?
1983 kz440 ltd
Quack
Quack
Last edit: 22 Jan 2013 21:23 by martin_csr.
- Kidkawie
- I bleed premix
04 Sep 2012 11:57
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- Killman
04 Sep 2012 12:01
Just took another look at them. They're cold like metal, but seriously light, and the back seems too shiny to be aluminum.
I don't have the best sensation in my hands anymore. Too many years in kitchens and slapping around Kempo pads. Sometimes it's tough for me to feel stuff and judge small weights.
But the emblems are NOS and I'm guessing yours are also original. So if yours are metal then mine should be too.
How did you cut the threads onto something that tiny Martin?
1983 kz440 ltd
Quack
Quack
- Killman
04 Sep 2012 12:03
Thanks Kidkawie. Those look perfect! I'm not going to snap the studs with those if I need to take them off, or have you tried it yet?
1983 kz440 ltd
Quack
Quack
