larger gas tank
- mjohnson7633
larger gas tank
28 Aug 2012 23:13
Hey all.
Looking to increase range of bike. Is there a larger tank that is available to just bolt on. Or something close with slight mods.
Looking for 5 to 6 gal capacity. I have spare tank that i can use the base and build one from scratch off of that but was wondering if wasn't something already available. Want to increase range but also have something to lean on when I'm really leaning into bike.
78 KZ1000 LTD
93 Vulcan 750
93 Vulcan 750
Re: larger gas tank
29 Aug 2012 10:20 - 22 Jan 2013 23:39
I don't know about the big bikes, but a 750 Standard-4 tank (4.2 gals) will bolt-on to a 750-Ltd (3.3 gals), BUT the Ltd triple tree will bang against it.
Last edit: 22 Jan 2013 23:39 by martin_csr.
- BlackZ1R
- Kawasaki in my blood
Re: larger gas tank
29 Aug 2012 12:20
I have a standard tank on my LTD1000. Close to a gallon more fuel.
Now, if you get really thirsty for more fuel, you can do a mohawk tank mod for another gallon or so.
Not sure what it would look like on a KZ :whistle: Here's one on a ZRX.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
The following user(s) said Thank You: shap
- mjohnson7633
Re: larger gas tank
07 Sep 2012 01:48 - 07 Sep 2012 01:50
I may just hold off on the tank project til I'm home. I may stick to my original idea of cutting top off my spare ltd tank and building it up. Once i have new handlebar on bike I'll know how much room I'll have between stock tank and my chest/belly
Best I've managed to baby out of kz is right at 30mpg so every ounce of fuel will help
78 KZ1000 LTD
93 Vulcan 750
93 Vulcan 750
Last edit: 07 Sep 2012 01:50 by mjohnson7633.
- BlackZ1R
Re: larger gas tank
08 Sep 2012 00:32
Start with a KZ tank. You already have nearly a gl. more capacity.
Did you look at the MoHawk tank mod on the ZRX? That's wild.
Check your PMs Johnson.
Kawasaki
- jeffasaki
Re: larger gas tank
08 Sep 2012 01:06
i have one already done
ill post a pic soon
probably 2x capacity
off a endurance racer
ill post a pic soon
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- jeffasaki
Re: larger gas tank
08 Sep 2012 13:08
[attachment:1]C:\fakepath\015.JPG[/attachment]
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- jeffasaki
Re: larger gas tank
08 Sep 2012 13:10
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
