My bike came in primer black, What should I do?
- ironslave
- sup
24 Aug 2012 01:54
I am planning on painting my bike since it came in primer black. I am considering using Duplicolor Metalcast for the job.
Since this is essentially a tinted acrylic clearcoat I will have to beforehand spray it with an aluminum base coat ahead of time.
The bike already has a black primer coat on it but I dont know what they used. they did the tank, side covers, and exhaust pipes. (it doesnt have the rear fender)
Should I strip it and start over, using the directions suggested by Duplicolor and spraying the adheasion/alluminum/Metalcast
Leave it on and correct any blemishes and then aluminum/Metalcast (i'm not sure how to fill in scratches from use)
Or Strip it and primer/Aluminum/Metalcast?
1981 KZ750 LTD
- Je77ekz1000a
Re: My bike came in primer black, What should I do?
24 Aug 2012 07:05
Strip it! You don't know whats under that flat black. Would not be good to spend money and time just for it not to last due to bad prep work that you had nothing to do with..... :pinch:
Jesse Shasteen
77 KZ1000 A
Huntsville AL
77 KZ1000 A
Huntsville AL
- Motor Head
24 Aug 2012 10:59Je77ekz1000a wrote: Strip it! You don't know whats under that flat black. Would not be good to spend money and time just for it not to last due to bad prep work that you had nothing to do with..... :pinch:
+1 Strip It.
- ramtough_63
24 Aug 2012 11:09
primer is a good way to hide bad prep work I would recommend sanding it out before
spraying any paint on it.
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- ironslave
- sup
28 Aug 2012 02:11
thanks for the responses, I will strip it!
I kinda stripped a spot under the filler cap and there was still factory paint and rust.
1981 KZ750 LTD
