Taking Care of New paint
- kzz1king
30 Jul 2012 16:33
I had a friend paint my bike. It looks great but seems like it gets the very fine scratchs (hazing?) easily. What is the best metod/materials to cleanand wax to minimize this? Oh yeah, it is black.
Wayne
Wayne
Home built KZ1000 turbo setup
- z1kzonly
Re: Taking Care of New paint
30 Jul 2012 21:33
Hand Glaze! That's all you need.
- wireman
30 Jul 2012 21:59
What kind of paint?
- kzz1king
30 Jul 2012 22:44
base coat/clear coat. What is hand glaze?
- wireman
30 Jul 2012 22:57 - 31 Jul 2012 00:18Attachment rndnc-wax_a.jpg not found
Ive had really good luck with this over the years,Ive also used turtle wax
Last edit: 31 Jul 2012 00:18 by wireman.
- Tomolu5
30 Jul 2012 23:03
Hand glaze is a very very very fine rubbing compound that you apply by hand. When applying wax to dark vehicles I always go in straight lines rather than circles, it reduces swirl marks(just make sure you rub it in pretty good.
Other products I have had good results with
- 3m swirl mark removed
-this 2 part system just for black cars, called black ice or something
-collinites insulator wax(kinda greasy, so it requires a lot of work to make it look good) this stuff lasts a long time.
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
- kzz1king
31 Jul 2012 00:07
Thanks for the ideas. What is the best material to use for application and polishing?
Wayne
Wayne
- Tomolu5
31 Jul 2012 19:11
Terry cloth towels for polishing, foam applicator for wax, microfiber for removing wax haze
Mine:
The following user(s) said Thank You: Humenik
- rcook52459
31 Jul 2012 19:22
3m products for removing marks and micro fiber cloths for putting it on and taking it off.
1983 750 spectre,all stock almost 16,000 on it on 1980 Suzuki gs1000l
- rcook52459
31 Jul 2012 19:23
3m products for removing marks and micro fiber cloths for putting it on and taking it off.just make sure there clean
- kzz1king
12 Sep 2012 23:09
After much research spurred by products listed here I bought some 3M Handglaze and Professinal wax. If you think motor oil discussions are something research wax!!
Anyhow both products work great but when do you use the handglaze? Between waxings? Confused as I have read it adds no protection to the paint.
Wayne
Wayne
12 Sep 2012 23:17
PaintWorkz wrote: Paint from the mid to late 70's was mostly acrylic lacquer and that is what the Kawasaki Candytone paint acts like. The new urethane paints are more durable when done right, but if recommended dry times between coats are not followed, or products are mis-matched, or tank was not cleaned or prepped correctly, I can see the clear wrinkling when soaked with gas due to a poor chemical bond between base coat and clear, or original paint and primer. Also paint manufacturers say to let paint cure for 3 months before waxing, so if you gas up a one week old paint job you are asking for trouble. It takes a paint job a year to cure before it gets good and hard.
