Painting Over Chrome
  • kzz1king
  • kzz1king's Avatar Topic Author
30 Jul 2012 16:28
#539577
I am thinking of painting my V&H megaphone until I can find a replacement. What do I need to do fro prep? No rust,just dull with a lot of haze. Thanks
Wayne
Home built KZ1000 turbo setup
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: Painting Over Chrome
30 Jul 2012 16:54
#539583
I roughed up a header with my sandblaster.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
30 Jul 2012 17:24
#539590
i have also bead blasted chromed parts and then painted them with lasting results.
  • MFolks
  • MFolks's Avatar
30 Jul 2012 17:50
#539596
Chrome plating should be roughed up, to allow the paint to "stick", otherwise, it will flake off. I suppose if you don't have access to a bead/sandblaster, some 180 grit wet sandpaper will work, just wash off the part afterwards for a good paint job.
If possible,let it air dry for an hour and try to bake the completed paint project in an oven at 300F for another hour. the baking will make for a durable finish.
  • kzz1king
30 Jul 2012 21:16
#539619
I can't bake it but could put it in a closed vehicle in the sun for a day and then hopefully the heat from riding it will help. Thanks
Wayne
