ELR stripes
  • ThatGPzGuy
  • ThatGPzGuy's Avatar Topic Author
ELR stripes
23 Jun 2012 13:37
#531245
Hey gang, I am picking up the painted bits today so I can apply the ELR stickers. What do I need to know besides what is printed in the instructions?
Also, from the pics I have it looks like the white kerker graphic goes over the dark stripe? Would that need to be cleared over first?
TIA, I'll post some pics in a separate thread.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • donthekawguy
  • donthekawguy's Avatar
Re: ELR stripes
23 Jun 2012 14:39
#531257
Just keep everything really wet with soapy water and you will be fine.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • ThatGPzGuy
Re: ELR stripes
23 Jun 2012 15:57
#531276
Ok What about putting graphics on top of graphics?
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • camaroguy
  • camaroguy's Avatar
Re: ELR stripes
24 Jun 2012 19:43
#531495
I didnt do a lawson rep but I did stripe it. when I did mine I put the stripes on and then cleared over them.came out good. and it protects the vinyl stripes
  • ThatGPzGuy
Re: ELR stripes
25 Jun 2012 08:15 - 25 Jun 2012 09:26
#531587
camaro guy, I am definitely going to clear over them. The pieces already have several coats of clear when I give them back to the painter he will add several more. The question I have is the white KERKER graphics look like they go on top of the broad blue stripe on the tank. Can I apply this graphic directly on top of the vinyl or should it be cleared over first?
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Last edit: 25 Jun 2012 09:26 by ThatGPzGuy. Reason: oops
  • ThatGPzGuy
Re: ELR stripes
26 Jun 2012 13:50
#531892
Here is the response I got from Reproduction Decals:
Jim:
Hi. The decal can be applied directly on the stripes and then cleared over.
Thanks
Ellen
I did the fairing and the rear cowl last night. It's tougher than it looks and I had a hard time getting all the bubbles out. Tonight I'll tackle the tank.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • ThatGPzGuy
Re: ELR stripes
28 Jun 2012 22:58
#532490
Well that could have gone better. I ended up peeling them off they looked so bad. I must not have the gene that lets you apply vinyl stcikers over curved suraces. It was working well, I had it plenty wet but I could not get the stickers to conform to the tank without wrinkling around the curves. What's the secret? I don't want to mess up another set of stickers those things are pricey!
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • 0Z.Z1R Mk2
  • 0Z.Z1R Mk2's Avatar
Re: ELR stripes
29 Jun 2012 00:07
#532513
Try using a hair dryer or something similar to get the wrinkles out.
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
  • ramtough_63
  • ramtough_63's Avatar
Re: ELR stripes
29 Jun 2012 08:41
#532569
do you have a vinyl squeegy? kind of looks like a bondo spreader?
dont overdo the soap and water
trick: use masking tape tape your stipes where they go (tape the edges of the application tape the stuff that covers the stripe is the application tape)
peel the backing off lightly spray the tank and stripe use squeegy to sqeeeze the water/soap out from one end to to other or middle outward let dry before proceeding
if no application tape is on the stripe you can do tape directly to the stripe
seems you either get crazy sticking power or almost no sticking with fresh paint make sure your part is really clean before you star
no sticker residue or it will show up under your stripe and look bad
air bubbles will occur take the tip of an exacto poke it push air out
The sun is your friend after it has dried the heat will shrink the viyl to remove air pockets
pm me if you need anything else
one layer of vinyl have cleared color sand ridge out add top sticker reclear colorsand and buff
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • ThatGPzGuy
Re: ELR stripes
29 Jun 2012 22:43
#532718
ramtough_63 wrote: do you have a vinyl squeegy? kind of looks like a bondo spreader?
I used a credit card.
I used a strip of painter's tape to determine the top edge.
Do you take all the backing off at one time? I was just peeling enough to work with the exposed part. Just a few inches at a time going from left to right and smoothing as I go. The sticker would stick like crazy and have to be pulled off if I messed up or could not get the wrinkles out. Once it touched the tank it was there to stay. Maybe I don't have enough soap in the water? The instructions said to use just one drop.
This is really frustrating. I wish Repro would post a few videos showing the best way to do this.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
