engine paint
- bradley77
- 1977 kz650c
engine paint
23 Jun 2012 00:46
im planing on painting my engine soon is there any special kinds of paint that are better than others give me some ideas, thanks
- donthekawguy
Re: engine paint
23 Jun 2012 14:44
Cheap bbq paint works great. I even used it on headers and it stays nice for at least a season.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- 4TheKZ1000
Re: engine paint
23 Jun 2012 16:14
Motor Coater is real good. You have several steps to follow, but gives show quality finish. You might not use it but look into it.
- MFolks
Re: engine paint
23 Jun 2012 18:22
The PJ-1 "Fast Black" is a pretty durable paint(if you like a black engine).
Smooth paint
www.denniskirk.com/fast-black-epoxy-paint.p30296.prd
www.jpcycles.com/product/900-660
Wrinkle paint
www.phatperformanceparts.com/PJ1_Fast_Wr...16_WKL_p/53-6028.htm
Smooth paint
Wrinkle paint
- bradley77
- 1977 kz650c
Re: engine paint
23 Jun 2012 18:28
i dont want something that will only last for a season im trying to find something that will last.
MFolks- ill deffinatly look into that paint
bradley
bradley
- MFolks
Re: engine paint
23 Jun 2012 18:41
For additional durability, if possible(and with the wife's or girlfriends O.K.) bake the black PJ-1 sprayed parts in an oven at 250-300 degrees for 60 minutes. The paint may outgas & smell, but do the baking with windows open. The finished paint job will be almost impossible to remove without grit blasting.
- MFolks
Re: engine paint
23 Jun 2012 18:52
I forgot to mention, after spraying the parts withthe black PJ-1 paint, let it/them air dry for an hour, and then do the baking. I use hooks made from old wire coat hangers, but brazing wire will work along with 16 gauge buss wire.
- DoctoRot
Re: engine paint
23 Jun 2012 21:54
if your looking for good durability, you may want to consider Gun Kote. it is similar to ceramic paints, but it has very good heat dissipation characteristics. It is very strong if surfaces are properly prepared and you bake it on correctly. I scraped my starter cover with a screw driver and had a difficult time scratching it. It also comes in many colors and sheens, however if you get black or olive green DO NOT BAKE IN YOUR HOUSE as they have trace amounts of lead in them. I got a oven for $10 on Craigslist and hooked it up in my garage.
www.kgcoatings.com/protective-coatings/2400-series-gun-kote/
- ThatGPzGuy
Re: engine paint
15 Dec 2012 21:21MFolks wrote: For additional durability, if possible(and with the wife's or girlfriends O.K.) bake the black PJ-1 sprayed parts in an oven at 250-300 degrees for 60 minutes. The paint may outgas & smell, but do the baking with windows open. The finished paint job will be almost impossible to remove without grit blasting.
Hey my wife has a brand spankin new kick ass oven so there is no way she'll let me get away with baking my parts in there. So... this may seem crazy but has anyone ever used a gas BBQ? I can maintain 250 degrees pretty easy and I can put the parts on a sheet of aluminum foil.
Why wouldn't this work?
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- MFolks
Re: engine paint
15 Dec 2012 21:36
I'd think a new,unused Gas or Charcoal BBQ would work, but if it has been cooking meat, the grease may vaporize, coating your engine/bike parts, making for a finish you'd not want.
The following user(s) said Thank You: ThatGPzGuy, wireman
- 0Z.Z1R Mk2
Re: engine paint
15 Dec 2012 21:38
PJ-1 paint is the ducks nuts....
I don't see why the BBQ method wont work.
I presume you talking about one that has a hood on it?
Just check it periodically and keep the parts raised of the hot plate.
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
- les holt
Re: engine paint
15 Dec 2012 22:49
"PJ-1 paint is the ducks nuts...."
I live in a community where hog nuts are a once a month special at the local bars and If you can catch enough "duck nuts" you might have the tools to open your own place.
Sorry, I had to add to this. :laugh: :laugh: :laugh:
By the way, I use the grill but I go upwards 300 deg. It stinks and she frowns but I usually burn it off real good before the steaks, burgers, and or ribs get their turn. To date I haven't had complaints either way.
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
