Looking for a recommended paint/KREEM remover
  • Bad Kaw
  • Bad Kaw's Avatar Topic Author
  • Flying Squirell
31 May 2012 19:41
#526170
Hi guys, I'm going to remove the KREEM from my fuel tank; anybody every used any service out there? I'm not looking to do it myself. I'm looking for a service that might do something like a chemical dip. I had found a place a couple years back, but that was one-crashed-computer ago and I have lost his information. If they have to strip the paint to get the KREEM out, I'm fine with that, too.
Thanks!
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • 750steve
  • 750steve's Avatar
Re: Looking for a recommended paint/KREEM remover
01 Jun 2012 22:43
#526352
Acetone should do it. & you can do that yourself. Just be carefull with the paint.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
  • wireman
  • wireman's Avatar
02 Jun 2012 01:39
#526389
I wonder if a radiator shop could get it out for ya? B)
  • PaintWorkz
  • PaintWorkz's Avatar
02 Jun 2012 10:12
#526429
Some big cities have Chem-Strip or Ready-Strip locations, Metro Detroit has Internatinal Stripping Co. All are chemical dipping ....strips inside and out.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
  • Z-Igor
  • Z-Igor's Avatar
02 Jun 2012 17:03
#526465
Hi Mate,
I don`t think you will get all of the coat of the winkles from your tank. You should better look for another one derust and protect it with acids. Never trusted the Kreem procedure. It`s just coating stuff over material without healing it itself.
Best,
Igor
1980 Z250A2, 1980 Z500B, 1979 Honda CJ360T
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
02 Jun 2012 18:18
#526467
wireman wrote: I wonder if a radiator shop could get it out for ya? B)
That seems to be a regional service...around here (SE Texas) none of the radiator shops will dip a tank. Elsewhere, others have had better luck working with their local shops.
I have also heard that acetone will remove tank liners...in addition to MEK...wear gloves and work outside...both those chemicals are rather nasty.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Sellitto42kz
  • Sellitto42kz's Avatar
  • Sellitto
02 Jun 2012 18:19
#526468
Ive also heard kreem will "Mix" with octane Boost if u put that in ur tank... No to sure if true..
I used Kreem on my 74'z1.. before using it used gas with nuts an bolts shook it up for awhile an then when i used the kreem the acid worked very well.. an then the coat over it made it perfect... but I hear both ways with kreem
its a easy 30$ fix but possible temporary?
B-)
  • vick074
  • vick074's Avatar
03 Jun 2012 03:12
#526548
2nd radiator shop..
